Results 1 to 6 of 6
Thread: How to find this center?
    Feb 2006
    us
    Ok let me describe my problem. On another thread somebody posted a pic of a damper for the stepper motors which I decided I would try to make since I was having some resonance problems. I milled a 2x5x1 steel parallel and faced one long side. Next I zeroed in the block, on the y and z this was no problem, but on the x since I didn't mill the ends of this block , I just eyed it , figured it wouldn't be a problem because it really didn't matter as long as I was close. I milled out the two center holes first(these go all the way thru), then the controller pc froze up before I could start the next op which was the 9 hole pockets circle pattern, I got the part zeroed back in as close as I could(was off by .020 but figured after I milled the 9 hole pattern I would go back and re mill the center holes as they needed to be enlarged anyway), I finished the 9 holes and had to leave , put the machine on hold and over nite the power went out. Now I need to find the center of the 9 hole pattern. Any ideas on how I can do that? Heres a pic http://www.cnczone.com/forums/attach...1&d=1200072366
    Feb 2006
    us
    As you can see in the pic it's kinda hard to find the center because the holes are not directly across from each other. And yes I wish I would have faced off the ends so I could have correctly zeroed in the x and I wouldn't have had this problem(kicking myself in the head as i type) but its a little late and because the machine is a cnc Sherline took 8 hrs to mill out the 9 hole patterns I don't want to remill them if i don't have to.
    Aug 2007
    Jul 2005
    Pick up the centers of three evenly spaced holes. These give you the corners of an equilateral triangle. Now use a bit of trigonometry to calculate where the center of this traingle is, that is the center of your part.
    Feb 2006
    us
    Figures I would figure out right after I posted this. Actually the hole that is to the right of the center of the pattern is pretty close to the center line of the whole piece(off by .0008). So I,ll just pick up from that hole bring my mill over from that and re bore the centers. Thanx guys for the quick replies.
    Jul 2003
    New Zealand
    Here is a VB program that I've written that will do the calculations. Just enter XY of three points.
    Attached Files Attached Files
    1. How to find center taps on 8 wire stepper
      By Rodm1954 in forum General Electronics Discussion
      Last Post: 10-23-2007, 10:38 AM
    2. HOW BIG IS YOUR CNC Machining Center?
      By boxxer_boy in forum CNC Machining Centers
      Last Post: 04-10-2007, 06:31 AM
    3. what to do with center tap?
      By truman in forum General Electronics Discussion
      Last Post: 01-20-2006, 11:21 PM
    4. PLC center for repairs?
      By Lasershop in forum Bridgeport and Hardinge Mills
      Last Post: 12-10-2005, 12:48 PM
    5. Find the center of a circle
      By Hobbiest in forum WoodWorking
      Last Post: 01-28-2004, 12:24 AM
