Old 01-10-2008, 07:32 PM
*Registered*
fivefishcnc is on a distinguished road
What router bit(s) do I need?
Apologies if this is not posted in the right section. I am new to this whole milling/CNC thing.
I am planning on doing some milling on aluminum material. And maybe some wood for "artsy fartsy" decorative stuff.
But primarily, I want to be able to drill holes and square cutouts on 0.06" thick aluminum alloy (5052-H32). And also on 0.125" anodized aluminum alloy (5052-H32).
The smallest hole is going to be 1/8" and the largest hole is going to be 7/8".
Can anyone recommend a router bit to use for this purpose?
Question2: Are there different router bits for metals, for wood and for acrylic? Is there a general-purpose router bit?
Question3: I may want to try doing some PCB milling. Is there a special kind of router bit for this purpose?
Other Info: The CNC is a home-built machine (bought from eBay), the router is a Bosch Rotozip RZ25. Software is Mach3.
Thanks for your time.
Router Using 3/4" MDF (first router build) eguy208 CNC Wood Router Project Log 33 04-11-2008 10:33 AM
Using a router for the 1st time. Need advice of cut speeds, router bits etc. Apples DIY-CNC Router Table Machines 19 09-23-2006 03:33 PM
Surfcam PP for Isel router / Precix router IvanTochev Post Processor Files 2 05-12-2004 12:27 PM
