Old 01-07-2008, 06:25 PM
smoke is on a distinguished road
Help Drilling AR500
The challenge is to drill a pilot hole in this material. It is about 500 Brinell and we would like about a 3/8" pilot. After the pilot the following work is going OK. To this point we have tried carbide with Simstar 700 coolant. Any suggestions for a better approach woould be appreciated.
Norm
Old 01-07-2008, 07:29 PM
djr76's Avatar
djr76 is on a distinguished road
Use a 7/16 cobalted screw machine drill at low sfm, drill just deep enough till you get desired diameter of pilot. I'm assuming you are using a center drill and breaking the points?
Old 01-07-2008, 09:29 PM
It is 1" thick plate that ends up with a 18mm hole plus a chamfered relief (82 degrees?) part way through. A friend of mine is doing this. Getting the initial hole through has been his problem. After that the additional operations are going OK. Since I posted he has found he had a CJ7 Kooltwist drill that is doing OK (It is about 3/8) Some research on this and a source tomorrow may solve the problem. We need to have a source in Edmonton AB. Any or all suggestions are for sure welcome.
Norm
Old 01-08-2008, 06:25 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
I find punching or waterjet to work really well.
18mm is a little too small to punch in 1" though.
Neither of these help with the chamfering.
www.integratedmechanical.ca
1mm or 0-80 drilling in al star1280 General Metalwork Discussion 10 12-18-2007 10:07 PM
Drilling on the TL-1 DivMechDes Haas Mills 9 11-02-2006 12:46 PM
drilling and drilling cycles tutorial wmorre General Metalwork Discussion 0 10-18-2006 06:30 PM
q about drilling o1 eaven Composites, Exotic Metals etc 3 08-05-2005 08:20 PM
Drilling .09 thk SS Machine1 Hard and High Speed Machining 17 12-12-2003 11:46 AM
