Old 01-07-2008, 02:25 PM
chuck99z28 is on a distinguished road
Front panel milling dimensions
I've been working on this electronic project and I created a front panel using Front Panel Express.
Their work is great, I really like the result.
My measurements are spot on when it comes to lining up the buttons to the holes. But it seems the panel's holes are exactly the same size as the buttons which go in them. So I can't fit the buttons into the holes unless I seriously file out the holes.
I think I just need to enlarge the hole dimensions and resubmit the job, but I'm not sure how much larger to make them.
Any recommendations?
Old 01-07-2008, 02:45 PM
keebler303 is on a distinguished road
Measure it!
Get some calipers and see how big your switches are. Make the holes .005-.010 bigger.
Matt
Old 01-07-2008, 02:55 PM
They are exactly .500 and my holes are exactly .500 as well.
Old 01-07-2008, 03:09 PM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
If the buttons are secured by a threaded post I would open them up .010-.015. If they are pop in and retained by spring tabs, I would suggest filing to fit.
The spring tab mounted switch manufacturer's recommended dimensions usually are a good starting point but I have found that they are usually a little too sloppy for my taste. You don't want the fit too tight as if may interfere with the operation of the switch or button.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 01-07-2008, 03:15 PM
MrWild is on a distinguished road
Looking at your top plate, the corner radiuses are larger than the corners of the buttons. When you file the openings, you will need to pay attention to these areas. The same size openings as the buttons issue isn't that bad. Just a little will go a long wayonce your corners are fixed.
Old 01-07-2008, 04:22 PM
mxtras's Avatar
Silver Member
What's with the "Kill" button? Sounds kinda dangerous....
That's a good looking panel, BTW.
Scott
Old 01-07-2008, 04:49 PM
Kill bypasses the whole device. Removes it from the chain. Kills it.
Its a midi controlled audio matrix switch.
drawer front inlays mike hide WoodWorking 14 01-11-2008 11:02 AM
End of Program - Front and Center donl517 Fadal 11 10-10-2007 08:40 AM
SX3 Head front panel Caution! keen Syil Products 4 04-10-2007 10:43 PM
Can I add more LED's to CPU front panel? Fluxion General Electronics Discussion 1 01-29-2007 10:10 PM
CNC-Zone Mug with logo on front and back samualt Suggestions for the CNCzone.com site. 1 07-29-2004 08:00 AM
