So I got what looks like a nice Rohm 1mm-25mm or so keyless chuck from my uncle when he passed away (along with other tooling), and I want to use it on my cheapie chinese lathe. Problem is, it has a 3/4" arbor in it, and I need it to fit a #3MT. I got a #3 MT to mate with the chuck, but I have no idea how to get the current arbor out. I see there is a collar and set screw (which I loosened), but how do I get the dang thing out? I know its just a friction fit, but what do I do - beat it with a hammer? - That sure doesn't seem right! TIA |
Im a newbie too. I had a similer strugle and used a automotive ball joint fork. put it between the pressed in bit and the back of the chuck. set the whole mess on a 4X4 piece of wood. tapped the fork with a hammer and the taper of the fork popped the two apart. The chuck wouldnt allow me to open and tap through the center as it was not through. Worked for me and didnt damage the chuck. |
| Thanks for the ideas... it is just as ugly as it seems! The rohm chuck seems to have a backing plate in it, in which case I can't use a punch (I'll go look closer). I also don't have a ball joint fork (got new-fangled cars ![]() Thanks. |
| You need a wedge set to pop the shank out of the chuck. Here is a link to Rutland Tool Supply and the item similar to what you need. http://www.shoprutlandtool.com/webap...roductId=78919 Later... |
Now that I know the method, I'll "git er done".Thanks all. I ordered those little wedges, and naturally they don't quite fit right. Worse, they don't have enough stack height to the it apart - I may be stuck and have to get a new chuck Last edited by Spinnetti; 01-12-2008 at 02:19 PM. |
| Need advice, newb question here. | DerHammer | Fanuc | 6 | 11-13-2007 12:23 AM |
| Newb Question | rubikahn | Servo Motors and Drives | 3 | 06-06-2007 03:09 AM |
| newb has a question | Rookie | General CNC (Mill and Lathe) Control Software (NC) | 7 | 05-14-2007 07:21 PM |
| Newb question about Lead surfacing | Sam A | General Metalwork Discussion | 2 | 05-14-2007 07:07 PM |
| Newb question | csmith0413 | Stepper Motors and Drives | 3 | 10-03-2005 01:17 PM |
