| Mill finish on Aluminium sheet. I wish to get a consistant mill finish on sheets of aluminium. I have tried randon orbital sanding but it shows each pass of the sander. Its shows the track that the sander took. I have thought about sand blasting the sheets but havnt yet tried that. Does any one have an idea of how to get a consistand mill finish accross the whole sheet, without it showing tracks. |
| Excuse my ignorance, but what is "mill finnished"?
| Do you mean you don't want to see any marks at all? Try using very fine paper on a random orbit sander, like 400.
| If the surface is in excellent condition, likely all you would need is a Scotch-brite product. I would imagine that if you want a "parallel finish" that you're going to have to use the edge of a "wheel" and take lengthwise passes with it. A fine, soft wire bristle wheel may also accomplish this surface conditioning. If you have sanding gouges to remove already, you could wrap a sheet of emery cloth around a short length of a padded 2 by 4, and take parallel strokes with it.
| Do you mean "brushed" fininsh. How big are the sheets and how many do you need to do? I'm thinking big belt sander 1400 wide, any help? |
| For a non-directional matte finish, get a hook and loop backing pad for your random orbital sander and cut yourself some circles from maroon scotchbrite. They'll stick well enough to the hook and loop for use like this so long as you've got the sander in the random mode and not the spinning mode. Keep the surface wet, as this prevents bits of aluminum from clinging to the pad and scratching the surface. Pay attention to keeping the pad flat on the surface, and don't let it rock up on edge, and the resultant finish will be very uniform. For a brushed finish, a pneumatic sander which resembles a dough rolling pin can be purchased. It has handles at each end and the drum rotates. Does an excellent job, but the sander itself is very expensive, on the order of $600+ US last time I noticed. |
| Benny: A nice "finish" on sheet is the "engine turned" you use a round wire brush in a low speed spindle then just touch the sheet move forward 3/4 of the brush and repeat so you end up with overlapping circles. |
| Thanks guys for your responses. I will give them all a go. Kong the only way I can describe a mill finish is like sandblasted glass, but in this case on aluminium. It is a uniform finish across the whole sheet and there are no discernible paths. I guess like white noise on a TV, only much finer. I will post some pictures of the results, after I have tried each method. EDIT: I noticed at out hardware store they are selling sandblasting attachments that fit onto a standard compressor. They only cost 20 bucks. I think I will give this a try first. Last edited by ynneb; 07-03-2004 at 10:16 PM. |
| Benny, sand blasting and glass blasting while two distinct types of blasting are often grouped under the term sandblasting. In your case you would want a fine or very fine glass media (depending on what finish you desire) if you decide to blast and definitely not silica sand. Glass would leave a smooth and very attractive matte finish Ken |
#10
| I tried the maroon scotchbrite pad and it works beautifully. Thanks for the tip metlmunchr.
__________________ -Patrick _____________________________________________ measure twice, cut once - a good rule for everything |
#11
| Scotchbrite is good! yep... |
#12
| Mill finish is when the chrome wears off of the rollers at the mill.Before the chrome wears off the metal is called bright metal.It would be very hard to reproduce a mill finish. |
| 3 Flute High Helix Endmill Problem | Joe_CNC | General Metalwork Discussion | 7 | 07-19-2005 08:07 PM |
| Tree Mill conversion Questions | Flyinfool | General Metal Working Machines | 7 | 05-27-2005 11:37 PM |
| how to mill 7075 T6 sheet material | gcamlibel | General Metal Working Machines | 11 | 09-08-2004 02:06 PM |
| Cutting bit questions | CNCadmin | General Metal Working Machines | 11 | 02-20-2004 04:12 PM |
| Routing Aluminium sheet | kong | DIY-CNC Router Table Machines | 11 | 06-10-2003 01:51 PM |
