i am currently machining a modified O.D. 3.5"-5 buttress in DOM tubing. by modified, i mean that the customer has changed the major Ø and minor Ø to accomodate their customers mating part. the mating part is a plastic cap that is used on a hydraulic tank for the fill tube. the parts are subject to below freezing temps, so that is where the modification came in. anyway...having trouble with a nasty burr at the first thread - can not get rid of the darn thing. i've tried to re-machine the lead in angle after threading 18 passes, and then re-cutting with 4, 6, or 8 passes to attempt to clean out the threads. i've even gone as far as trying to machine a linear step at the start to minimize the lead in chamfer size, but to no success. result is always the same - a razor sharp edge on the first thread. any one have any ideas on how i can resolve this matter? also, i'm using a kennametal nt4rb insert. they recommend that i use a negative 15° modified flank infeed. anyone heard of this? i've done modified infeed angles, but i'm a bit confused on the -15° infeed...any input would be greatly appreciated. |
| I would say you need to put a quick/blunt start on the 1st thread. do this with a grooving/part off off tip a little wider than the thread form - re run this tool in a s/cut cycle going 1 to 1.5 of the thread depth from the start of the thread - also start half a pitch in from where you started the s/cut tool. ie.. 5mm tpi s/cut tip started at z 10. start groove tool at z 7.5 finish at z -5.0 this will remove the feather edge. then repass with s/cut tip as original s/cut cutting to deburr sides. should be left with a nice start to the thread. ST |
| not quite sure what you mean here. pardon the stupidity, but i'm a bit slow on the uptake. i have a 3.5 inch, 5 threads per inch o.d. thread. so, my pitch is .200", and the thread is 45°, 7°; the 45° is the leading egde. all i need to do is knock off the burr at the start of the first thread. again, sorry for the lack of understanding. thought maybe i was not explaining correctly. thanks |
| No worries, to remove the feather edge ( razor sharp first thread ) you need to blunt/quick start the thread you can do this as mentioned by using an external groove tool in a screw cutting cycle or mill it on with live tooling. both will remove the sharp edge. ST |
| The kind of start you are looking for is what is called a "Higbee". I think that is the correct name/term and if you Googled this you might find something. What you do is program a flat tool, such as a grooving tool to cut down the center of nhe thread and do a rapid pullout. This removes the feather edge that is at the start of just about any thread. And I have to admit I have never done it successfully on a lathe but when thread milling it is a snap.
| HIGBEE! It sort of works...i still get a bit of a sharp edge where the first full thread is at the major Ø...here's what i have: N7T0303(THREAD O.D.) (3.5 - 5 BUTTRESS) (KENNA NTB4RB KC5025 INSERT) (HOLDER NSR 164D) G97S450M3 G0G55X3.6Z.4M8 G76P000500Q0R30 G76X3.2015Z-.96P1200Q283F.2 G0X10.Z7. M1 N8T0404(HIGBEE) (USE 5MM ISCAR GROOVER) (GIMF 502 IC9054) G97S450M3 G0G55X3.6Z.4M8 G76P030500R0Q0 G76X3.2Z-.2P1220Q461F.2 G0X10.Z7. T0400 M1 N10T0303(RE-THREAD O.D.) (BURR CLEAN-OUT PASSES) G97S450M3 G0G55X3.6Z.4M8 G76P050500Q0R0 G76X3.2015Z-.96P1200Q1200F.2 M9 M5 G0X10.Z7. M30 Any thoughts or suggestions, let me know. Thanks to all...appreciate the help. |
| Voice Your Opinion On "POLYMER CONCRETE FRAME" Thread! | walter | Polls | 13 | 04-27-2012 07:19 PM |
| Index to "Epoxy-Granite machine bases" thread | walter | Epoxy Granite | 13 | 12-01-2011 10:45 PM |
| V18.0 Spiral Thread post has no "Z" Output | twt | BobCad-Cam | 11 | 09-09-2011 08:58 PM |
| Another " Moving a Tormach to a basement" Thread | Scott_M | Tormach PCNC | 10 | 03-30-2007 10:08 AM |
| Thread not showing up in the "New Post" section | Mr.Chips | Forum Questions or Problems | 1 | 10-23-2006 02:14 AM |
