Old 12-29-2007, 12:19 AM
pmurdock is on a distinguished road
Keyway broaching on Lathe (need Y axis?)
I've tried doing all the reading I could on the best way to create an internal keyway inside a bore. I've found the PH Horn broaches that seem to be what I'm looking for. they suggest mounting them in the turret. I have a Haas SL-30 with live tooling (C-axis) on its way and I'm not quite sure whether this CNC lathe is capable of using these broaches as there is some confusion in my mind about what I will need a Y-axis on my lathe or not (which I don't think it has).
any thoughts about keywy broaching on a lathe?
cheers!
Paul
Old 12-29-2007, 08:52 AM
HuFlungDung's Avatar
Moderator
It should be possible without a Y axis, as I used to do the odd one on an ordinary manual lathe. What you'd need is the flexibility to orient the tool so that the insert axis is parallel with the X (cross slide) and then you can increment the cuts in X.
Interesting find, BTW. I didn't know anybody made tools specifically for this
Old 12-29-2007, 09:03 AM
This has been discussed previously; do a search using 'broaching lathe' and you will get several threads/posts.
Old 12-29-2007, 09:20 AM
Yes it has been discussed and that's how I found out about the PH Horn parts , but I didn't see anything about a Y-axis.. However the other question about how to orient the face of the tool on the X-axis. If you don't orient it just right the flat of the keyway will be all messed up.
cheers,
Paul
mazak integrex broaching precisiontork Mazak, Mitsubishi, Mazatrol 5 10-27-2008 07:57 AM
Keyway or not to keyway... That is the question jessbussert Stepper Motors and Drives 5 12-16-2007 07:14 AM
Broaching advice Al_The_Man General Metalwork Discussion 9 12-19-2006 05:03 AM
Automating the Broaching process Donald Mechanical Calculations/Engineering Design 20 10-20-2006 04:09 PM
Broaching without a broach or press? Chris D General Metalwork Discussion 9 09-23-2005 02:47 AM
