Results 1 to 3 of 3
Thread: Work Holding
    Jul 2007
    Work Holding
    I have a project of drilling three 2.00" holes in 4 X 5 rectangular tubing . The tubes are 99 inches long the holes are 47.5 inches apart. Tolerance are .010 on location. I have 60 inches of travel so two set ups are a must. I could have up to 2 thousand to do. I am looking for ideas on a quick & solid work holding fixture . This is a horizontal mill with two large angle plates. I am leaning toward two air vises. I don't know if they will hold with no part movement. Any input to this would be appreciated.
    Thanks daveb56
    Mar 2006
    Dave, Air vises should hold the pieces without movement.
    Personally I'd make a drill fixture and drill the holes with a magnetic based portable drill and a "slugger" or "roto-bore" tool. Might be a little more complicated if the holes go thru both sides of the tubes. Might require the fixture to pilot a longer tool. Can be done, I believe.
    Dick Z
    DZASTR
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    Similar to RICHARD, I would use a Roto-Brute cutter.
    I would set up a jig on a mill table (preferably a long one).
    The jig would have a 1.995 pin on it at exactly 47.5 from the spindle.
    End stop for the first hole. 1st hole on the pin for the 2nd hole. 2nd hole on the pin for the 3rd hole.
    NO clamping or table movement would be involved.
    www.integratedmechanical.ca
  1. Holding Tenths On Cnc?
    By aceofspades25 in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 01-30-2007, 11:17 AM
  2. Work holding
    By reachraghu in forum Employment Opportunity
    Last Post: 12-11-2006, 07:24 AM
  3. Holding torque Ncm vs Oz/in
    By George in forum Stepper Motors and Drives
    Last Post: 12-14-2005, 03:58 AM
  4. Work holding????
    By anoel in forum General Metal Working Machines
    Last Post: 10-14-2004, 01:07 PM
  5. Work Holding Methods
    By InventIt in forum DIY CNC Router Table Machines
    Last Post: 09-14-2004, 04:13 AM
