Old 12-20-2007, 05:55 PM
orionstarman is on a distinguished road
D2 drawn down toooo long
I put some 5/16 D2 plates in the draw down oven after heat treating and than forgot about them. Total time at 400 degrees was about 4 hours. Are the plates ruined?
Old 12-20-2007, 06:16 PM
kn6za is on a distinguished road
d2
How much lower is the hardness, than what you were trying to get?
Andrew
Andrew Abken
www.drewtronics.net - PCB Cutters
Old 12-20-2007, 06:29 PM
Well we just checked them and they are at 60 rockwell. I think we were shooting for 62 so they are not as bad as I thought they would be. This is the 2ed time that I've done this.
Old 12-20-2007, 06:42 PM
d2
Yea, I remember the time I forgot to remove a 420ss plate from the oven at 1870deg - it was in for 10hrs not 1 hr like it should have been.
I did not need to ask if the plate was any good, it nearly disinigrated!
I doubt your plate suffered much from its long draw, if 60rc is acceptable I would think it to be just fine.
Andrew
Andrew Abken
BCC Tech says that this shape can't be drawn with V22 TZ250 BobCad-Cam 11 12-02-2007 01:13 PM
How Long/RPM skydivebase Haas Mills 5 08-19-2007 07:29 PM
Click On Drawn Entities TURNER Visual Basic 1 05-17-2007 10:41 AM
How long does it take CNCadmin Steam Engines 4 11-08-2006 09:45 PM
What have you drawn and built entirely on bobcad?? AMCjeepCJ BobCad-Cam 23 01-31-2006 02:09 PM
