If I am reading this correctly, Send it out....unless you and your equipment have the capability to handle up to 1550mmx1550mm(60"x 60") x 75mm(3") thick square plate of near 1 metric ton(2200lbs.) capacity.
The supplier should have the capability to cut it for you. That is BIG stuff for a router! Will the CNC plasma machine you have cut through 75mm Aluminum and cover the travel range to cut the 1500mm diameter?
DC
LinkBack URL
About LinkBacks
. The router will be removing lots of material using a minimum 3/4" cutter for 3" depth around 188" circumference. Long cutters need to be held very true at those spindle speeds as vibration is a major problem. That still sounds like several days of cutting.
