Old 12-12-2007, 11:13 AM
cbr120 is on a distinguished road
4 Axis Feedrate Calculation
I am using a GE Fanuc - 4 axis in a laser system (X,Y,Z,A). I have a matercam generated post that has extremely high feedrates on some tight corners. It is moving around the corner using the Y,Z, and A axis.
Is there any way that I can calculate what the feedrate should be. I trust the mastercam but I have to make some changes at times and would like to know how to calculate the feedrate manually.
Thanks in advance.
Old 12-12-2007, 11:20 AM
samco is on a distinguished road
I have no experience with anything over 3 axis. I hear though that inverse time feed is better in these situations.. where you tell it how long you want it to cut the line segment instead of how fast along the line you want to cut.
(if that made sense..)
(a bit over my head here)
oz-calculation help needed methuso Stepper Motors and Drives 3 09-25-2007 09:39 AM
Getting ready, need help calculation TCNC slp_prlzys DIY-CNC Router Table Machines 4 07-22-2006 05:23 PM
Is this calculation correct? h3ndrix Stepper Motors and Drives 4 02-07-2006 12:08 AM
resistor calculation need help mike10 Stepper Motors and Drives 2 03-29-2005 09:21 PM
Back EMF calculation? OCNC Stepper Motors and Drives 12 12-08-2004 10:03 AM
