Old 12-12-2007, 07:28 AM
SteveGT4 is on a distinguished road
Help with using long series endmills
Hi, i have to mill a pocket 80mm deep in aluminium with a 10mm endmill. Is there a general rule of thumb as to how to adjust the speed and feed of a long series cutter compared to a standard lengh? I just managed to snap a brand new reduced shank 3 flute alu geometry endmill using the rpm my cam software gave me which was 6000 rpm (m/c's maximum) and i gradually crept the feed up. It got to probably no more than 100mm per min when the cutter shank broke. I didn't even get a chance to play with the rpm! Any recommendations?
Steve
Old 12-12-2007, 12:35 PM
djr76's Avatar
djr76 is on a distinguished road
How about 'Plunge roughing' the cavity out then do the finish pocketing/profiling.
Old 12-12-2007, 01:58 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
a broken tool wouldn t be caused by the feed or speed ,especially at 6000 rpm . what was the depth of cut and engagement
1mm endmills/bits johnm99 CNC Tooling 10 09-17-2007 12:24 PM
Coolant Fed Endmills eorourke General Metalwork Discussion 10 06-21-2007 09:35 PM
Sharpening Endmills ADCORGUY Toolgrinding & Toolgrinding Machines 0 03-30-2007 07:55 AM
Endmills in Canada??? mindstorm88 DIY-CNC Router Table Machines 0 07-28-2006 08:44 AM
Anyone used these endmills? Cold Fusion General Metal Working Machines 8 09-12-2004 11:16 PM
