Old 12-11-2007, 08:38 AM
ozzie34231 is on a distinguished road
Reconditioning and rust
I see pictures of very badly rusted machines that get reconditioned to beautiful, new looking machines.
What are the ways re conditioners deal with rust?
Ozzie
Old 12-11-2007, 10:57 AM
Ozzie, There are many ways to remove rust. I like rubber gloves, steel wool, deisel fuel, automatic transmission fluid and elbow grease. There are commercial preparations as well. Of those, I like Kroil. I'm sure someone will suggest water displacement 40th attempt AKA WD-40. lol
After removing the rust, there is usually some/much additional effort in correcting surface damage and geometry correction.
Dick Z
DZASTR
Old 12-11-2007, 12:53 PM
Thanks Dick,
Do I read you second paragraph to say that a new looking machine that was fairly rusted has had the ways re machined or scraped?
I've removed rust but never get anything like shiny new metal.
Ozzie
Old 12-11-2007, 01:07 PM
NC Cams is on a distinguished road
We've picked parts in muriatic acid - right from the jug - as in the type you etch floors wtih and it TOTALLY removes rust from sound steel. It does not seem to hurt the good, sound metal if you watch what's going on. The steel has a matte finish after etching and can be buffed to a luster. Any pitting from the rust will remain forever as oxidation ha taken its toll - the acid TOTALLY removes oxidation/rust however and other stuff you don't need or want.
We've picked cast iron and, depending on the alloy, it cleans it nicely. Some alloys, however, the acid attacks with wild abandon. Hardened alloy steels are sometimes left OK and sometimes ATTACKED - It varies. Try test parts that are not particularly precious if you're unsure. Forget aluminum or any zinc plated parts as the reactions are not pleasant.
You can "soften" the action of the acid by simply adding distilled water. The acid can be used over and over and it is not particularly expensive. use, nutralize (backing soda and wter) and dispose of properly as, after all, it is a hydrocchloric acid based chemical!!.
Old 12-11-2007, 01:27 PM
Ozzie, As usual, NC is also correct. I don't like the acid thing because it stinks and I can't stand the smell. lol I thought your question involved severely rusted components. That usually includes pitting which on machine ways is not welcomed. The pitting can be removed by filling (I don't usually recommend that) or resurfacing by grinding, scraping or? as you noted. I've seen ways that look fine after NC's acid cleaning and then polished by stoning etc. However, you should still check the geometry after polishing to be sure it still has the capability to hold the tolerances you require.
There's some fine looking polished junk on e-bay every now and then, buyer beware and all that.
Dick Z
DZASTR
Old 12-11-2007, 01:37 PM
ironDigit is on a distinguished road
if its real precious electrolysis seems te best in MHO.
or anything acid from coca-cola to hydrocloric chemicals ,and some rubbing is almost always involved.steel wool and scotch-britepads seem to bust-rust as well as leaving a nice finish.after using acids on your projects always neutralize with baking soda or the rust might be back faster then you can rub.
trow some searches for electrolysis and you'll find better then i can explain in no time.
good luck.
Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
Old 12-11-2007, 02:18 PM
martinw is on a distinguished road
Dear Ozzie,
Try this...
http://www.cnczone.com/forums/showth...highlight=rust
Post two has a link to electrolysis details..
Best wishes
Martin
New SX3 (green with a little rust red) Yojinbo Benchtop Machines 3 09-13-2007 11:10 AM
Rust and tram Vern Smith Haas Mills 5 06-26-2007 06:22 PM
Ballscrew with Rust! bcromwell Linear and Rotary Motion 2 04-04-2007 01:06 AM
Table reconditioning MrRage Knee Vertical Mills 10 02-06-2006 09:13 AM
rust prevention coolman General Metalwork Discussion 2 01-22-2005 11:32 PM
