Old 12-10-2007, 05:16 PM
Loading is on a distinguished road
Feed and Speed for milling 304 Stainless
Hello all,
I've got some 304 which I need to get a 'nice' finish on. I'm not to sure what I'm looking for. It only needs to look good.
I've got a 5 flute carbide 1/2 end mill. I'm thinking that with a very small stepover might leave a neat finish.
Other then that I've got a 1" 3 flute indexible end mill, or a 2" 5 flute indexible face mill.
Feeds/Speeds for those?
Thanks!
There is a shop near to me I could bring em to that has a large surface grinder.
Old 12-10-2007, 05:37 PM
djr76's Avatar
djr76 is on a distinguished road
If your finish profiling, then I would use the carbide endmill
conservatively
1/2" 5 flute carbide S1500 F37.5 for .005 ipt
Use the Face mill if that is your intentions is only to face the top, you will get alot less small crosshatch lines in the work piece if you used the 1/2".
About S250 F6.25 for .005 ipt
Newbie to CNC aluminum milling feed/speed/depth/coolant, etc. mrk General Material Machining Solutions 4 03-30-2009 01:51 PM
TM-1 and milling stainless CJH Haas Mills 13 07-29-2007 08:43 AM
Optimizing Milling - Speed, Feed & Depth of Cut palikalsi General Metalwork Discussion 5 04-03-2007 04:59 PM
stainless feed and speed help 1ctoolfool Haas Mills 17 03-23-2007 02:18 AM
Feed/Speed Milling Alum Rekd Hard and High Speed Machining 7 11-26-2003 10:55 PM
