  #13
Old 06-26-2004, 05:10 PM
IJ. IJ. is offline
Gold Member
IJ. is on a distinguished road
Smythe: I'd grab the phone book and ring a few of the medium to large engineering firms in your area, most will have power rollers.
How precise does the form need to be?
The amount of heat needed to bend an 18x70 sheet of 1/2 inch would be amazing as aluminium disipates heat quite well, then you would need a master form to bend it to........could be done but the logistics of handling a huge heavy sheet of HOT aluminium would take some working out.
  #14   Ban this user!
Old 06-26-2004, 05:22 PM
smythe is on a distinguished road
IJ. - Thanks for the info, it the bends need to be pretty acurate in order for the laminated material to come out correctly.
j
Old 06-26-2004, 07:19 PM
*Registered*
metlmunchr is on a distinguished road
A 6' long piece of aluminum plate will sag noticably under its own weight when supported at the ends. The stiffness won't be there for laminating press use unless it's attached to some supporting structure which would provide the necessary section depth and attendant stiffness. One psi applied across an 18 X 70 surface produces a distributed load in excess of a half ton.
If the budget is tight, you might look at wood (logs, not lumber) for something cheap to get the necessary section depth. The deflection under load will vary inversely with the elastic modulus, but it will vary inversely with the cube of the section depth. This is why things which cannot stand deflection HAVE to be thick. For starters, you'll need to know the required laminating pressure for your materials. That will allow you to calculate the loading and deflection of various materials and sections. Trying to decide what will work without knowing those basics would be akin to designing a bridge without being told whether it had to support a Honda or a battleship.
  #16   Ban this user!
Old 06-26-2004, 09:26 PM
metlmunchr- point noted and appreciated. As it stands right now I am currently working with wood for the mold. The reason I was looking for an alternative with the aluminum, was its heating characteristics. There would of course be a supporting structure behind each half of the mold to support it while under pressure.
j
Old 06-27-2004, 12:24 PM
ger21's Avatar
Why not use a thin aluminum sheet attached to the wood substrate?
  #18   Ban this user!
Old 06-27-2004, 12:55 PM
ger21- thats the current plan, I am just worried that the heating element that I will use will make the surface uneven.
  #19   Ban this user!
Old 08-05-2004, 07:08 PM
Ries is on a distinguished road
Did you ever try to build this mold?
You probably couldnt get the profile you want with rolls- rolls leave a flat spot at each end of the curve, and are really for making parts of circles- the way to make this from sheet would probably be with a large press brake- but to bend 6' of aluminum that is 1/2" thick, you are probably talking something like a 100 ton press brake.
Big fabricating shops and some larger sheet metal places might have a brake this big.
But what about starting with a solid block of aluminum, and routing out the depressions you want- aluminum will rout pretty easily with carbide bits, and then you could touch up with a belt sander. Use a circular saw or table saw to mill slots in the back, and put in strip heaters- how hot does your composite need to be to go off? plexiglas bending strip heaters are basically just resistance heat tape, 110 volts, get to around 2 or 300 degrees, so you could put a bunch of them in the back of your aluminum form, and wait for it to get hot.
This kind of 3 d form is exactly how they make carbon fiber and composite parts for B-1 bombers- except the molds cost hundreds of thousands, if not millions, and the composite fiber is laid up by cnc robots, and then the whole thing goes into room sized ovens to set off the presoaked composite. Boeing only pays 10's of millions of dollars for setups like this, so there is no reason you shouldnt be able to duplicate their effort for nothing with no tools, right?
I have a neighbor who could make you this form, no problem- he makes em for Boeing- he has a room sized cnc router to do just this- but I think he is a little above your budget- Janicki Industries in Sedro Wooley Wa.
Old 08-05-2004, 07:32 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Arrow
Originally Posted by smythe
HFD- I am only going to be pressing composite material..I would like to make the top and bottom molds
out of either 3/8" or 1/2" sheet aluminum, length is around 70" width is about 18". I
I confuse easily sometimes - but maybe its just 'cruise-heimers!
I know you asked about "SHAPING ALUMINUM" but:
What type of composite materials are you considering? Foam and 'glass with epoxy/poly resins? Or honeycomb - boron fibers or something simple, paper and glass ala TPG?
There may be a number of ways to get the project done with a variety of different materials and a range of dimensional tollerances.
You don't have to let on to what your building - but a few details might help focus the forum help - maybe you "don't need" alluminum to press it!
Maybe a simple vacuum set up over a single male mold with pre-preg might get you where you want to be? Maybe I missed the details in the previous posts?
My 2 pennies - odd isn't that? money is metric yet inches are not?
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
  #21   Ban this user!
Old 08-06-2004, 11:35 AM
Ries- Yes, I have started. I am moving forward with my original plan making the mold out of wood and then covering the surface with thin aluminum that will be heated. Regarding having have the molds milled from block aluminum, this of course is what I would like to do eventually once I get the final shapes of the molds dialed in. The reason I wanted to know about "shaping aluminum", my thinking was is that it might have been cheaper to use a sheet/plate of aluminum and then bracing the shaped sheet so it would not distort under pressure. Thanks for the info on the rollers and for the contact.
High Seas- Materials would be thin wood to plastic with glass and epoxy. Yes a vacuum table works, but press times are increased with the table. Even with a heat source for the table, cure/press times are longer than with press both surfaces. Pre-preg could be an option but then I would need an oven. '
Thanks to both of you for the suggestions and info.. I appreciate it.
J
How strong? (Linear rails, aluminum structure) WoodSnarfer Mechanical Calculations/Engineering Design 13 07-15-2005 11:29 AM
CNC Aluminum studysession General Metal Working Machines 6 02-12-2005 09:39 AM
aluminum extrusion georgebarr DIY-CNC Router Table Machines 19 11-04-2004 09:43 AM
Can I use Forstner bits on aluminum? samualt DIY-CNC Router Table Machines 14 10-24-2004 12:35 PM
Can I dry mill Aluminum? UCFMems General Metalwork Discussion 6 07-22-2004 05:30 PM
