Old 12-06-2007, 09:50 AM
Fidelity_Mold is on a distinguished road
Help Setting the Read-Out for lathe?
I have a uniq sds2l readout for our lathe and our operator has tried to switch the readout to read diameter instead of radii. This way he can move in and see exactly what he is taking off. Anyone have any ideas...there is a R/D button but I cant get it to do anything?
Old 10-25-2010, 11:09 AM
Kevin Schmidt is on a distinguished road
clear any measurement in the X axis. Then press the X axis button. Then press the Rad/Dia. button. This will switch the display. Caution...... You may also need to set the muliplier of the axis based on the pitch of the lead screw.
Setting 51 on Toolroom Lathe 1ctoolfool Haas Mills 6 09-20-2007 02:28 PM
Setting Up Custom tools in X lathe Davidimurray Mastercam 1 01-31-2007 04:54 AM
Setting up job as mill or lathe? Art Ransom Machines running Mach Software 0 10-20-2006 06:38 PM
setting a boring bar on lathe laamar General CNC (Mill and Lathe) Control Software (NC) 1 03-06-2005 07:36 PM
