Old 12-03-2007, 07:43 AM
zooloader's Avatar
zooloader is on a distinguished road
In line keyways
Hi All,
I need to make two 18mm keyways 120mm long, from either end of a 300mm long sleeve 60mm id, which need to be inline to accomodate a 600mm sliding shaft with an 18mm keyway its full length.
The sleeve was designed to be keyed the whole length as well, but our slotter has only 200mm stroke.
I'm not sure how I can turn the sleeve over for the 2nd key and align them perfectly.
I will have holes at the end of the keyways for the tool to break into, and was thinking of using a dowel in these holes to run a clock along?
All and any suggestions welcome, thanks.
Old 12-03-2007, 05:48 PM
kwhizz is on a distinguished road
Clamp a ""V" Block to the O.D. and Indicate it in, when you turn your part around , indicate the bottom of the "V" block again for radial alignment....works for me........
Ken
Old 12-05-2007, 02:40 AM
zooloader's Avatar
Heyy, thats a good idea Ken! I'll remember that.
thanks.
Old 12-05-2007, 09:49 AM
Andre' B is on a distinguished road
You could cut the full length like the way rifling is cut in a barrel.
A single cutter on a head which can be adjusted for depth of cut with a screw or shims. The cutter head is easily removed from the pull rod for the return stroke adjusted and put back in place to make a cut.
Could be setup in a larger lathe, or a simple 2 by 4 frame, and pulled by hand.
Here is a drawing of an old key-seating machine, maybe give you some ideas.
http://books.google.com/books?id=-5pKAAAAMAAJ&pg=PA29
Tool for cutting internal keyways etc... M-man CNC Tooling 7 08-19-2010 10:05 PM
Dm2400 Line By Line Execution???? andrewtub Benchtop Machines 6 01-25-2010 10:28 PM
Line Smoothing, point /line no identification dz1 Visual Basic 8 12-15-2007 05:03 AM
I need help with keyways! iprogcnc GibbsCAM 2 10-08-2007 05:39 PM
