Old 11-29-2007, 10:01 PM
*Registered User*
fpworks is on a distinguished road
Toolholding for small drills
I have to drill a bunch of little holes. I already have the 0.032" drills (with same size shank), but I'd like another option in terms of how to clamp.
I found a Mitsubishi carbide version with a 3mm shank, but lead time is 1-2 weeks, which isn't going to work.
Next option was to direct clamp on the 0.032" diameter with a DNA conversion for my existing ER16 toolholders, but the collet from Techniks was about $100, then I also have to buy a nut, and spanner wrench. Kinda pricey.
Any other options?
Old 11-29-2007, 10:29 PM
307startup is on a distinguished road
Buy a pin vise, MSC cheapie all the way to Starret, and load the drill into it, then the pin vise into your collet. Absolutely easiest, most accurate method I have ever used. Of course finding the spindle speed necessary for such tiny drills and the ridiculously small peck depths is another matter.
examples:
http://www.ehobbytools.com/index.htm...tml&lang=en-us
http://www.king-tool.com/industrial.htm
http://www.widgetsupply.com/page/WS/...n-vise-jeweler
http://www.grainger.com/Grainger/items/4KY33
http://www.grainger.com/Grainger/items/4KY34
http://www.fastenal.com/web/products...ex?sku=0324856
I'm sure you get the idea...hope this helps!
I personally recommend Starret pin vises...catalog No. S240Z EDP 51140, the set runs from .010-.055", .025-.075", .045-.135", .110-.200"
Old 11-29-2007, 10:37 PM
star-turn is on a distinguished road
i second wyld's advice
Old 11-30-2007, 07:54 AM
*Registered User*
Thanks! I assume you clamp on the knurled portion? If so, what kind of run out on the tool do you get?
I've only got 12k rpm to work with, but thankfully, I only have to drill 0.080 deep.
Old 11-30-2007, 08:52 AM
kreutz is on a distinguished road
You can use carbide drills made for PCB work, they all have 1/8 shank.
http://www.drillbitcity.com/
http://www.thinktink.com/
Be carefull, runout on the collet will break the smaller ones.
Old 11-30-2007, 09:12 AM
*Registered User*
Thanks...that is what I tried to find, but none of the PCB specific drills have the required flute length. (that I could find)
If I can find something with a 1/8" or 3mm shank, that would be ideal...I can clamp those with a hydraulic toolholder with 1-2 microns of runout.
Old 11-30-2007, 12:06 PM
kalmah is on a distinguished road
I think that the Schunk Tribos tool holding system is the best for microtool
http://www.schunk-usa.com/schunk/sch...EN&lngCode2=EN
I've this system. The concentricity is always lower than 0.005mm. I've already drilled 0.016" in maraging steel. It works perfectly. I think it's impossible with other tool holder.
Old 11-30-2007, 02:41 PM
vulcom1 is on a distinguished road
I am not sure what you are drilling or what tool you are using but I just drilled 8 holes 1/4" deep in brass and carbon fiber. The drill size was .8mm so it is in your range. I bought to try some carbide bits from Princess Auto in Canada but most cheaper outlets have them as they come in a little box and mine had different coloured plastic rings with the sizes on them. They are cheap and worked fine for me.
I broke a couple on my drill press but then thought I would try my mill/drill. The 1/8th inch shanks fit in the 1/2inch chuck and I ran it at top speed. With the part clamped it did not take long to peck through the material. I did the 8 holes with one bit. It looks funny with the little bit in the chuck but it also let me know it was running true.
This info may help.
John
Old 11-30-2007, 07:23 PM
When drilling prototype PCBs I always drill 0.1" holes (depth) using those drill bits @ 30K rpm without problems.
Old 11-30-2007, 07:49 PM
dfstrasser is on a distinguished road
Mikron offers small drills up to 15XD in length. Look at the crazy drill at http://www.mikron.com/internet.nsf/id/tool-products_en . They are the best small drills on the market.
Breaking small drills in 6061 - what to do? SRT Mike General Metalwork Discussion 8 11-26-2008 06:19 PM
parabolic drills Machine1 Hard and High Speed Machining 18 06-11-2008 09:22 PM
PCB Drills aggie_67 General Electronics Discussion 7 03-07-2007 09:47 AM
Iscar Cam Drills jackson General Metalwork Discussion 1 01-15-2007 06:52 PM
carbide drills MBG General Metalwork Discussion 30 10-23-2005 08:03 AM
