| 'Lo guys. I am tapping a Letter 'F' sized hole in 303 stainless on a CNC lathe with a 5/16-18 tap. I am using an OSG Spiral Flute, steam oxide bottoming tap. The tap seems to be holding up fine but I am always on the look out to do better than fine. These tap's cost 14-16 USD and I don't mind spending more if the tool life increases. Just wondering what success you have all had with tapping 303 stainless. Which taps work for you, which taps make your head hurt. Thanks in advance! Joe |
| I tap 1/4-20 and 5/16-18 holes in 303 everyday at my job. I specifically use the OSG Exotap VA3 taps designed for stainless. They pretty much outperformed any previous tap I ever used and have been using them for about 8 years i think. Run it at 20-30 SFM using this formula RPM = SFM X 3.82 / Tap Diameter |
| I've had good success with intermediated 'Blue Point' Gun Tap from Goliath. Due to the grind, the chip comes out curly AHEAD of the tap. None gets in the flutes. These have been 3 and 4mm blind holes about 1/2" deep. One pass. Goliath recomended using intermediate, and I have not looked back since. Very good tool life. Can't remember the name of the magic tapping fluid used.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| Mine too, I work for an OEM food processing equipment, its all mostly 303/304 stainless, some 440C and 17-4 ph. |
| Problem Tapping Stainless | bobcor | General Metal Working Machines | 16 | 04-21-2008 02:35 PM |
| tapping 304 stainless with vf-2 | jprobst | Haas Mills | 2 | 06-12-2007 07:30 PM |
| Advice for 0-80 tapping in stainless steel | js machine | General Metalwork Discussion | 6 | 06-12-2007 03:06 PM |
| facing and tapping 304 stainless | 1cnchogger | General Metalwork Discussion | 19 | 02-26-2007 09:18 AM |
| tapping 303 stainless | bobcor | General Metalwork Discussion | 8 | 03-28-2005 04:58 PM |
