I need to drill 400 holes threw .250 thick 304SS, hole size is 7/16. I normally use HSS uncoated 118 deg screw machine drill bits in a manual mill. I plan on doing this job in my CNC mill, can you guys recommend a better drill bit and feeds/speeds for best tool life and a clean hole? Thanks Chris |
| for the hss drill that you have i would use the following (4 x sfm)/d=rpm sfm=50 d=.4375 (4 x 50)/.4375= 457 rpm rpm x cpt x # of flutes = feed rpm = 457 cpt = chip load per tooth = .002 # of flutes = 2 flute drill 457 x .002 x 2 = feed rate of 1.83 so rpm=457 feed=1.83 this is what i would use myself |
| I've tried and like a high helix cobalt drill for flood conditions. Dormer makes a nice set of high helix drills. Because 304 is soft, the high helix with split point promotes chip flow somewhat better than regular jobber drills. Moderate rpm allows coolant to get to the drill, and still you can keep the feedrate in the aggressive zone, so long as the drill is sharp and cool. Stop immediately if you hear an anguished squeak, and resharpen.
| :RFQ: 2 304SS Flanges | CarTunr22 | Employment Opportunity | 2 | 03-05-2007 09:48 PM |
| Machining 304ss with carbide endmill | nybuxt | General Metalwork Discussion | 3 | 12-10-2006 04:02 PM |
| drilling and drilling cycles tutorial | wmorre | General Metalwork Discussion | 0 | 10-18-2006 06:30 PM |
| q about drilling o1 | eaven | Composites, Exotic Metals etc | 3 | 08-05-2005 08:20 PM |
| Drilling .09 thk SS | Machine1 | Hard and High Speed Machining | 17 | 12-12-2003 11:46 AM |
