Old 06-17-2004, 11:54 AM
gtslabs is on a distinguished road
Surface Grinding irregular shapes square
I need some advice for surface grinding. I am girding flat the ends of Rock Cores from a drilling operation. I need to hold a tight tolerance of perpendicularity and flatness. However the shaft of the core is not always straight. They are sometimes tapered or bowed and this gives me problems truing the ends. My first step is to secure the piece in my v-block with the bottom elevate off the bed/mag. chuck. I then grind that flat. Next I flip the piece over and put the ground end directly on the chuck and then with down pressure I secure the sample to the V-block and grind the other end.
However at this point any error in the shaft is magnified and my ends do not end up parallel to each other. As I tighten the clamps the pice will lean in against the V-blocks at times. I try rotating the piece and regrinding and it is like chasing my tail at times.
What I need is a way to firmly secure the piece to the chuck at the base but still be rigid enough
to grind without moving the piece. I tried just using the lower set of clamps on my v-block but that did not always work either. My shaft diameter is approximately 1.95" and the length is about 4" - 4.5".
Any ideas on how to remove the irregular part of the shaft and still get a good surface?
I am attaching a picture of my set up. I also checked the flatness of my machine <0.0002 and my V-blocks are perpendicular.
Steve
Old 06-17-2004, 11:58 AM
Hmm, not sure why my attachment did not show up.
Old 06-17-2004, 02:31 PM
HuFlungDung's Avatar
Moderator
Steve,
Is there any way you can clamp the part to the V block, and never remove it until you are finished? I'm imagining that you would have more success by relying on the squareness of the ends of the V block, rather than the part.
Assuming that the part is longer than the V block, you could increase the height of your V block with a 1-2-3 block spacer between the V block and the chuck.
Old 06-17-2004, 03:50 PM
My V-blocks are 4 1/8" so yes my part is slightly bigger. So let the part overhang both ends of the V-block and use a spacer under the V-block and just flip it each time? That shounds great!
Am just learning Machining and did not know how to use 123 blocks.
Thanks - I will try and report back.
Steve
Old 06-18-2004, 06:57 AM
Gold Member
imserv is on a distinguished road
Steve, they make mag parallels that have alternating brass strips for magnetic setups.
Here is an MSC link for an example:
http://www.mscdirect.com/MSCCatLooku...rodID=79182416
About $60 per pair, 2x4 x 1 in high.
Those should work for flipping the V-block.
Fred Smith - IMService
Keep it clean.
Old 06-25-2004, 08:45 PM
BT1 BT1 is offline
BT1 is on a distinguished road
Precision grinding vice maybe?
BT1
How to make Parallel Square Beam/pipe without flat surface ? Calico Welding, Brazing, Soldering, Sealing 8 06-26-2005 09:13 PM
