Two flute gives more chip clearance for aluminum. It doesn't matter thaaat much. I usually just grab whatever is on hand. You'll find machinists that'll tell you that it matters and machinists that tell you that it doesn't.
And yes, if you run a 2-flute end mill on steel at 600 rpm then you'll have to go slower to get a real nice surface finish, but on aluminum running a 2-flute at 3k-6k it just doesn't matter that much.
LinkBack URL
About LinkBacks
). Finish is mainly about the about the amount of work each tooth is doing. Because the cutting speed of aluminium is so high (about 600fpm as opposed to steel at 100 or so), you can run a cutter very fast, and provided your feed rate is low compared to your spindle speed, then a two flute cutter can give a good finish.
