Hi, I was wondering if anybody could give me a good feed and speed for face milling aluminum plate with around an 8 blade shell mill? will coolant give the best finish and what rpm should I do also? |
| it depends a lot on your horse power and the type of insert, here is what I use 2000 rpm 64 ipm. But these are big thick parts and I have them very rigidly held down. I get just about a mirror finish which our customer is looking for. You would be much better off if you would ask your tooling supplier like I did. |
| GaryCorlew said it right...get your feeds/speeds from the tooling supplier or manufacturer. YES, absolutely run flood coolant. |
| My shell is made by moon cutter Co out of Connecticut. I went to their website but couldnt find any data on recommended feeding speed and RPM but I did find a material data safety sheet.... ![]() Anyways, not sure if this helps or not. but I inspected it a little closer this time and its a 3 inch HSS Shell mill with with 12 blades "not removable inserts". So its the type you throw away when its dead. thanks for the advice though, ill be sure to keep the coolant flowing when running it. |
With HSS on aluminum your sfm should be around 500 - 600, possibly a bit slower; I am going from memory here not having used this type of cutter for a long time. For 3" dia you will be using 500 - 600 rpm and with only 5 hp available you are going to be limited in your doc and feed. I would stay below 0.10" doc and try something conservative like 0.001" per tooth for the feed. This gives you 0.012" per rev or around 7ipm. Bump the feed up if things are going okay and the motor is not bogging down. Flood coolant is a good idea but you could get away with just a mist or even squirting coolant on by hand.
| thanks. Wow, I'm glad I asked because here I thought I was supposed to run the shell mill at like 2000rpm or something much much higher than you suggested. I've read some post on here where some suggest cranking it up and finding out what it will do. I personally like to play cautiously when I don't really know what I'm doing and learn what I can before hand. So then, I should be running a slower rpm and feed rate for the best finish. 7 IPM is much slower than I anticipated. Another nub question then, what exactly is doc? |
#10
| If you had a carbide insert face mill you probably would be able to run at 2000rpm; that is equivalent to 1800fpm cutting speed which is acceptable using carbide. There is nothing wrong with cranking things up but it is a good idea to start conservative; I did say bump up the feed if the motor can drive it without bogging down. When you have accummulated few years experience then you can dive in like a maniac on the first cut .
#11
| I run my 3.1 inch x 3 tooth face mill at 2000RPM and 23ipm and flood on but the teeth are carbide. I've run it faster and with more aggressive feeds but I work in my garage in a dense residential so I try to keep the noise down. |
#12
So today I actually faced a few aluminum plates. I ended up feeding at around 15 IPM about with my 3" 12 blade HSS shell. I had the spindle set around 750-800 RPM and my doc was taking off about .005. So now I have another question. No matter what combination I seem to try between feed and RPM, I end up with small ridges on the seems between the passes. There not drastically horrible, but they are there, which bugs me. If I had to take a guess, I would say that there maybe around .001 give or take a little judging from how it feels. Can anybody tell me what usually causes this, and what should I try next to break em down flush. |
| Aluminum face plates | chuck99z28 | DIY-CNC Router Table Machines | 2 | 11-08-2007 11:33 PM |
| Help with face milling... | peter.blais | General Metalwork Discussion | 18 | 09-24-2006 01:20 PM |
| Face Mills? Which one to choose for a good finish on aluminum? | peter.blais | General Metal Working Machines | 20 | 08-25-2006 10:41 AM |
| Face Milling techniques & workholding advice needed. | Moondog | General Metalwork Discussion | 7 | 11-10-2004 01:51 PM |
| VQC Face Milling three pass | Ken_Shea | Haas Mills | 3 | 08-12-2003 11:10 PM |
