Anyone know where I could run across large bore bearings (around 2.5"-3")? They don't need any type of taper as they're only holding weight on a single axis. I was thinking maybe something like Truck Axle bearings bight be a good size (not really sure though) and certain;y string enough...not sure on the price though. |
| Chris, The cheapest bearing you will probably find with that size bore is in fact the pillow block bearings for axles. The ones in the links below run from 40 - 90 us dollars. http://cgi.ebay.com/2-1-2-Bore-4-BOL...QQcmdZViewItem http://cgi.ebay.com/SealMaster-Pillo...QQcmdZViewItem Depending on your application, you could use plain oiled bronze flange bushings or ceramic bushings. The friction is not that bad depending on the surface of the rod. You can get these for about 6 us dollars a piece. However, it all depends on the application. RPM's, materials etc. If I knew a little more about the application I could recommend specific products. The cheapest new set of linear rods and bushings you are likely to find is through VXB bearings. http://www.vxb.com/page/bearings/CTGY/LM Again, without knowing the application you may need linear rails and bearing blocks. The cheapest source for those will be e-bay. Hope this helps and let me know if I can assist your further. You can just respond to the forums or contact me via www.cncroutersource.com. My email address is keven@cncroutersource.com. Regards and Happy Holiday
__________________ Keven WWW.CNCRouterSource.com |
| Where were you two weeks ago? I trashed a bunch of them in that size. I may have a couple left but I think the bore might be in the 4 to 5 inch range.
__________________ If it's not nailed down, it's mine. If I can pry it loose, it's not nailed down. |
| I just thought of the idea yesterday...sorry (lol) I've been looking at auto parts places and they do have complete bearings (looks like a sealed bearing, but not sealed) for truck axles. They're about $60 each. For what I'm doing I think that may even be overboard. The assumption is that if you have a 2-3" bore, you're supporting a ton of weight. I just need the through bore. I was considering just trying to find some small cheap ball bearings (the balls themselves) and just turn the race right into the case and the spindle. Or even just use three small bearings that the spindle can ride on. This solution is just somewhat "cheesy" for this app IMO. 2muchstuff, About those 4-5"...I wouldn't mind hearing a little more about those. |
| Truck axle bearings are probably overkill capacity wise but might be the easiest approach.
| I ran across a the jackpot. A place called Industrial Liquidators had a pretty big assortment of large bearings. They were all under $25. That said, I'm going to experiment with different ideas over the big weekend. If my idea works (a big IF), it has potential to be a resellable product. So basically I'll need to be able to work with "off the shelf" parts. I'm going into the garage right now to try my three bearing theory out. Plus I need to figure out how an easy way to create a spindle...specifically how to add a gear (or some method to control it's rotation). I'm going to try to cut through a gear I have, then I could potentially either weld it in place or weld and turn a mount and screw the gear to the mount. Anywa, my ears are still open for any good idea's or thoughts. Thanks. |
| looking for cheap v bearings... | kanankeban | DIY-CNC Router Table Machines | 14 | 04-09-2009 11:04 AM |
| Source for large qty of cheap linear ball bearings - round shaft | InspirationTool | Linear and Rotary Motion | 2 | 01-10-2007 09:00 AM |
| skate bearings versus linear bearings | paul langwade | Linear and Rotary Motion | 7 | 05-29-2006 10:06 AM |
| Lead Screw Bearings - Cheap is OK | musicmkr | Mechanical Calculations/Engineering Design | 6 | 01-07-2006 05:21 PM |
| Cheap V cut bearings. | ynneb | CNCzone Club House | 8 | 10-22-2005 04:06 PM |
