11-20-2007, 01:59 PM
Originally Posted by mantisory Hi all. I am not a machinist by any means, but i have a (maybe) dumb question.
I have some 3/8" thick 6061 AL plate that i want to drill a 22mm hole through. Also, on the same center I'd like a 28mm hole halfway through, as the picture shows:
However, I only have limited tools - a handdrill, a drill press, etc...
Question: is it possible to do this with the tools i have, assuming i am will to spend a few bucks on bits or whatever? Would a combination of spade buits work? Also, it is not necessary to have it super accurate.
Thanks,
Byron |
If you clamp workpiece down to drill table you should be able to drill a pilot hole say 5mm then drill out to 22mm dia try and use the bright finish drills as the alum sticks to black(steam finished drills)you will need a counterbore with a 22 dia pilot for a one off you could get a piece of 22 dia round and cross drill say a 5mm hole to take a brocken centre drill and sharpen this to give a single point cutting tool its easy for me as I was a toolmaker send me your email address I will draw up a sketch of what I mean regards shiney |
