Results 1 to 3 of 3
Thread: Slot, Drill, Thread -- Correct Order
    Oct 2005
    I need to cut this piece.
    http://bb.steelguitarforum.com/userp...crank_03_1.jpg
    There's a slot going to the larger hole and a threaded hole that runs through the slot. My question is, what's the right order to cut the slot and drill/tap the screw hole?
    Do I cut the slot and then drill and tap the small hole? Or do I drill and tap the small hole and then cut the slot?
    Gary Shepherd
    www.16tracks.com
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    save the slot for last , unless your working within tight tolerances , it depends a lot upon the material your using ,once you cut the slot the part may spring which will throw out the larger hole dia and the flatness
    Gold Member
    Apr 2003
    Ohio, USA
    Yes to dertsap's advice.
  1. Calculation Of Force In Order To Select Correct Spring
    By weaston in forum Mechanical Calculations/Engineering Design
    Last Post: 08-24-2011, 09:48 AM
  2. Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press.
    By Geof in forum General Metalwork Discussion
    Last Post: 02-01-2008, 02:32 PM
  3. Metric thread form tap, drill chart
    By conceptmachinin in forum General Metalwork Discussion
    Last Post: 08-27-2007, 05:31 AM
  4. Coated Carbide 4Flute Endmill, 3Flute Slot Drill, or 2Flute Slot Drill?
    By weaston in forum General Metalwork Discussion
    Last Post: 04-11-2007, 10:00 PM
  5. To End Mill or Slot Drill, That is the question.
    By Imagineering in forum WoodWorking
    Last Post: 09-02-2005, 08:41 AM
