Old 11-18-2007, 02:36 AM
sp1nm0nkey is on a distinguished road
Precision hole drilling?
I need to finish a hole to within 2 or 3 tenths oversize, will a ream get me this? The hole is 5/8s of an inch, so I don't know if they make hones that size, and I don't trust myself to lap the bore to size. Any suggestions?
Old 11-18-2007, 02:41 AM
Pres is on a distinguished road
The right size reamer should do it.
Unfortunately, some reamers are ground larger than that when they are brand new.
Lastly, a "rule of thumb" is 1/2 the rpm and twice the feed of drilling speed and feeds.
hth,
Pres
Old 11-18-2007, 07:27 AM
*Registered User*
fpworks is on a distinguished road
Your tolerance is +0.0002 to +0.0003, for a total tolerance window of 0.0001, so no, a reamer will not get you this.
Jig grinding or honing will. You may want to bore the hole undersize and send it out for completion.
Old 11-18-2007, 09:58 AM
ZipSnipe is on a distinguished road
A reamer will get you your 5/8 exactly. To get your couple of tenths honing might be the trick or boring bar but that would require some serious setting up.
Old 11-18-2007, 11:51 AM
rounsy222 is on a distinguished road
I agree with fpworks. A reamer will work under the right conditions but some much depends on your setup and loading of the parts, you can easily lose you tolerance. Always better to error on the side of caution. Best of luck!!
Old 11-19-2007, 07:31 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
If it is critical you jig bore.
If you like to gamble (russian roulette style) use a reamer.
www.integratedmechanical.ca
Old 11-19-2007, 09:12 PM
laka is on a distinguished road
Agreed. I dont think you'd get consistant results within a few tenths with a reamer.
Old 11-19-2007, 09:52 PM
Gold Member
Ken_Shea is on a distinguished road
Would sneaking up on it with an adjustable reamer be viable ?
Ken
Old 11-19-2007, 10:07 PM
Are you doing one hole or lots of holes...lots as in thousands? You are wanting 0.6252 to 0.6253 which is a tolerance of +/-0.00005 and more or less impossible with a reamer.
If you are doing lots you could look into ball sizing. This is a finishing procedure where you get to within .001 to .0005 below the final size by reaming or boring then expand the hole to the final size by pushing a carbide ball through it. The ball also puts a very fine finish on the hole which is needed when you are dealing with very small tolerances.
Old 11-19-2007, 11:58 PM
MrWild is on a distinguished road
I'm willing to bet this super high precision isn't even needed. There are good engineers, and there are clueless engineers.
  #11   Ban this user!
Old 11-20-2007, 12:30 AM
little bubba is on a distinguished road
There is a 99% chance that your customer's QC can't measure it, and the print is crap is anyway, and 3/4 hole would work, so (assuming MOST of my customers) I would use a .625 reamer, and a -.625 and a -.626 pin and call it good. Heck, if sombody farts in the QC room(at a tenth tolerance total), the temp will rise and you're hole is sCRAP anyways.
I'm sure there are times when a single tenth is called for, I'm not equipped to do it and I won't, I hope you are getting paid accordingly.
Deep hole drilling kalmah General Metalwork Discussion 8 09-09-2007 10:09 AM
Drilling a .010 hole CoolhandLuke General Metal Working Machines 7 03-25-2007 10:44 PM
Homebuilt CNC Hole Drilling Machine nitrosaturn DIY-CNC Router Table Machines 8 11-14-2006 02:44 AM
Drilling a hole in a 3D model mayhugh1 SprutCAM 5 10-25-2006 11:51 AM
Deep hole drilling on OKK eddie G-Code Programing 1 09-21-2005 06:55 PM
