Old 11-11-2007, 09:35 PM
eloid is on a distinguished road
diy gear box
I need to design a simple gear box for my steper using spur gears
i need some to help figure out a what gears to use for a simple 3.6:1 and 7.2:1 gear box for my stepper...my math is a bit rusty.... for calculating
this.
below is a picture of what i want, try to make as compact as possible
with out .....running 7.2 gear off a 1 inch gear eg.
Name:	7_2 to 1 gear box.jpg‎
Old 11-11-2007, 09:53 PM
DSL PWR is on a distinguished road
Unless you can cut a planetary gear set you will need to use several stages. More stages = more backlash.
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 11-11-2007, 09:58 PM
gears
if you use 2 gears to gear down and 3 to drive pinion whats best configuration
and diameter to use? dont know much about gears
Old 11-13-2007, 07:53 PM
keebler303 is on a distinguished road
The picture you showed is of toothed pulleys. The belt which connects them is not shown. This is much easier and quieter than a gear setup. It is what I would recommend for a rack and pinion reduction if you didn't want to spend the money on planetary gear geads for your steppers.
If you want to use spur gears, it is the tooth count that matters. So for 3.6:1 ratio use a 10 tooth gear driving a 36 tooth gear. 36/10=3.6
You will want to pick ready made gears if you want durability and accuracy. Boston gear is one option, there are many other suppliers. You need to size the pitch of the gear so that it is strong enough for the loads and fits within your space constraint. Any supplier can give you advice on strength and sizing. Most will list the pitch diameter of the gears. This is the diameter of the point of contact between mating gears. To find the distance between the centerlines of 2 gears:
(pitch diameter of gear 1)/2 + (pitch diameter of gear 2)/2 = dist. between gear centerlines.
Matt
Basic Bevel Gear - Milling a valley for gear teeth ngr1 General CAM Discussion 10 04-05-2012 09:55 AM
Spur Gear / Gear Rack ckrantz Linear and Rotary Motion 12 12-06-2006 11:06 PM
Should I gear rocks101 Stepper Motors and Drives 2 07-15-2005 10:00 AM
Why gear at all? andy_ck87028 Stepper Motors and Drives 6 06-27-2005 04:16 AM
gear mfj pyroracing85 CNC Plasma and Waterjet Machines 10 01-15-2005 05:40 AM
