Results 1 to 6 of 6
Thread: Internal threading on a cnc mill
    Mar 2006
    Looking at internal threading a .950” hole, about .5” deep. The thread are a very truncated “v”, 20 tpi (looks almost like an acme), the major diameter will be about .962”.
    Has anyone experience cutting these on a CNC mill? I was going to make a tap (about $250), but was wondering about doing them on the mill. I have many to do, but over a long period of time. I was wondering which way would be most cost effective.
    Jim
    *Registered User*
    Jul 2004
    Jim,
    Without a doubt, I would certainly threadmill those threads. As long as the threads are still 60 degrees, you could use an off the shelf threadmill for 7/16-20 threads to acccomplish this. I just checked the price at $115.
    Threadmilling is also a much more secure process with larger threads, and the threads turn out a lot prettier.
    I would imagine that inspecting the major diameter is going to be the expensive part, if you have to buy a gauge...I hope you have a part with the external threads!
    Justin
    Mar 2006
    Justin,
    I've got to turn the shank and thread it on the lathe.
    Wouldn't I have to grind the tips off the threadmill to get the
    truncated major diameter?
    Thanks!
    Jim
    *Registered User*
    Jul 2004
    Jim...sorry, I didn't think through it and thought your minor diameter was to be truncated.
    Yes, you would have to grind the OD of the threadmill. I imagine this would be fairly inexpensive for a threadmill manufacturer, since it would be a modified standard item, and not a full special.
    So, your minor diameter is 0.950 and the major is 0.962? If that is the case, you will still have enough thread on a ground down 7/16-20 threadmill.
    I've had good luck with threadmills from these guys: www.threadmillsusa.com
    Mar 2006
    Thanks Justin, I'll check 'm out.
    Nov 2007
    You can also check out the indexable threadmills, they may offer an insert with the trunification you desire.
    1. Internal threading tool suggestions
      By kdoney in forum Mini Lathe
      Last Post: 04-04-2013, 06:46 PM
    2. 1/4 - 20 internal threads
      By Runner4404spd in forum Mach Lathe
      Last Post: 09-25-2007, 01:34 AM
    3. Internal gears
      By itsme in forum Mechanical Calculations/Engineering Design
      Last Post: 01-04-2006, 06:39 PM
    4. HELP!! I need an internal groover!!
      By Everett in forum General Metalwork Discussion
      Last Post: 07-12-2005, 10:06 AM
    5. M97 Internal Subprograms?????
      By CAMCRASH in forum G-Code Programing
      Last Post: 03-24-2005, 01:10 PM
