Old 10-30-2007, 05:18 PM
SRT Mike is on a distinguished road
Boring aluminum getting messy on lathe
Any ideas?
I have a piece of 2.5" 6061. I drill a 1" hole 2.3" deep. Then I bore the entire thing to 1.25", then I bore the top 0.75" to a width of 1.9".
The main problem I am having is that when I am boring out the hole, I am getting long stringy bits of aluminum that fly around, curl up around the boring bar, get all wrapped up and lead to a crap-tastic surface finsh as they all get in the way of the boring bar.
Specs are...
2500RPM
0.100 depth of cut
0.005IPR
1/2" boring bar (I know I could use larger but I need this for some other jobs)
21.51CCMT insert that's positive rake and polished (made for aluminum)
I do not have coolant through the boring bar.
It seems the problem is that it's just not effectively breaking the chips. If the chips were breaking I could mess with the coolant nozzle to make sure it's blasting into the bored cavity and flushing the chips out, but when it turns into a bit string and wraps around the bar, it turns into a big ball that looks like steel wool and impedes the coolant flow as well.
I am thinking maybe its insert wear (doubt it - almost brand new insert)
Possibly my feed/speeds are off?
Maybe I am taking too big a cut? Too small a cut?
Any opinions are welcome!
Old 10-30-2007, 06:00 PM
riverrat is on a distinguished road
what does the mfg. say to run that particular insert at?
seems really slow with way to light of a feed rate.
mash the meat to that thing, and i bet your problem goes away.
"those who would sacrifice liberty for security deserve neither" Benjamin Franklin
Old 10-30-2007, 06:17 PM
Use the G74 Face Groove Pecking canned cycle. You can adjust both the length of peck and the amount of retraction; you do not need to withdraw completely from the hole just pull back a few thou. You can also adjust the X increment so you have two lines of code that bore all the way from your drill size to the 1.25" size then another two lines to go to the 1.9".
Old 10-30-2007, 06:19 PM
I got the inserts from MSC - it says "Broussard Enterprises, LLC" on the case but I can't find them by doing a web search.
I also am facing and turning an OD with a CNMG 432 insert at around the same speed and its taking forever. Its my first time running this program and aluminum so I could be way waaay off on speeds. A machinist next door told me that he never exceeds 1/2 the nose radius for the step-over so I was just sort of guessing here.
I was hoping I could crank that sucker up because the cycle time is long.
Can someone suggest a good range for roughing and finishing? I get an almost mirror shine on the OD with 0.003IPR 0.005DOC 2500rpm, but it's a pretty slow pass. I just cranked it up to 0.005IPR 0.100DOC for roughing and left it like that... but if I can go faster I will.
Old 10-30-2007, 06:23 PM
Geof do you happen to know if the Okuma OSP5000 control supports all 'standard' Fanuc G-codes?
The manuals for this machine look like they were written in Japanese, then translated to Latin by a dyslexic orangutan, then re-translated into Engrish by that orangutan's moron brother. It's not that they are imprecise, they go into painful detail on some stupid things (like how to calculate whether a tool in the turret will interfere) and gloss over things that are kind of important (like how to actually program a G2/G3 command correctly).
They manual just skips over a bunch of g-codes like most of the canned cycles. If the Okuma is standard Fanuc I know I can find the commands/parameters online
Old 10-30-2007, 06:25 PM
erd39030 is on a distinguished road
I think that you could use 0.015 IPR instead of 0.005, or even more.
is your boring bar too weak? is hanging out too much?
Old 10-30-2007, 06:29 PM
Its about 1/2" shank on the boring bar (tapers a little at the neck) - it's an 8-2 size. It's hanging out around 2.5" from the holder, although I am boring down 2" so I think it ought to be rigid enough.
I will try 0.015IPR and see how I do. Those little CCGT 21.51 inserts just look so.... dinky... next to the CNMG432 size that I guess maybe I was nervous to really push it in case I break something. I also didnt have much of a reference point to start with - but this is a good one, thank you!
Old 10-30-2007, 06:31 PM
For roughing aluminum on the OD you can use over 0.020 IPR, 0.200 DOC, and speeds above 1000 sfm (I would use G96 instead G97).
Old 10-30-2007, 06:34 PM
2.5 od on aluminum, i'm gonna say go waaaaaay more rpms, probably max.
as far as feed on the od turn, assuming no crazy finish callout, .01 per rev
even with a big depth of cut should give a pretty good finish.
just remember aluminum is a soft material, in order to break a chip, it
has to be pretty thick, .01 per rev is pretty conservative considering
i'm not sure of your machine, rigidity, etc.
hope this helps
Old 10-30-2007, 06:43 PM
hope this helps
Well max RPM's is 3000 but it's got a gigantic chuck on there that I dont like to spin more than 2500
The machine is plenty rigid, it's an Okuma LC-40 with a 60hp spindle motor. All the turning holders are 1.25" and I am holding the part in machined soft jaws.
I will try cranking up the speed to max and going with 0.01IPR and work up from there instead of 0.005.
At least I know .005 gives a beautiful finish for the finishing passes at 5thou DOC. I'll keep pushing and see how I do
  #11   Ban this user!
Old 10-30-2007, 07:22 PM
60 Hp?
That's a lot of machine for little .100 DOC on aluminum!
  #12   Ban this user!
Old 10-30-2007, 07:50 PM
Originally Posted by SRT Mike View Post
Geof do you happen to know if the Okuma OSP5000 control supports all 'standard' Fanuc G-codes?.....
The manuals for this machine look like they were written in Japanese, then translated to Latin by a dyslexic orangutan, then re-translated into Engrish by that orangutan's moron brother....
Can't help you on the capability of an Okuma. And I am tempted to report you to the Orangutan Antidefamation League .
Do you have a description for G74? I can screen capture a page from the Haas manual that describes it if you like.
Making 200+ Delrin Flange Nuts - Messy! widgitmaster Bridgeport and Hardinge Mills 8 09-08-2007 03:21 PM
Lathe Boring Titanium? Otokoyama General Metalwork Discussion 14 02-05-2006 09:22 PM
aluminum boring question metlcutr55 General Metalwork Discussion 4 01-23-2006 09:52 AM
turning-and-boring lathe 1563 promsnab CNCzone Club House 0 10-24-2005 10:40 AM
setting a boring bar on lathe laamar General CNC (Mill and Lathe) Control Software (NC) 1 03-06-2005 08:36 PM
