Does anybody have any tips for turning S154 steel on a STAR sliding head machine? I'm getting drag marks on the finished part. Using VCMT 160404 inserts. Bar diameter 16mm. Depth of cut 5mm. 1800rpm 0.04mm/rev. This works but anything quicker and the material just tears. I've tried different chipbreakers & grades. Any suggestions??? |
| Sharper insert. Have you tried a cermet? Something else to look at is are the chips hitting the finished surface? I know it sounds stupid but you'd be surprised much chips falling away from the cutting tool can affect surface finish. Try redirecting the coolant to blow the chips away from the finished diameter. You can always try to rewrite the path too but you might be limited since your on a screw machine.
__________________ I don't know much about anything but I know a little about everything.... |
| Cheap sliding ways | chuckknigh | DIY-CNC Router Table Machines | 6 | 02-04-2009 09:21 AM |
| What methods did you use for sliding motion | widgitmaster | Polls | 1 | 10-09-2007 11:46 PM |
| Composite dry sliding bushings... How good are they? | Brunow | Linear and Rotary Motion | 9 | 01-17-2007 06:04 PM |
| sliding into it !!! | craftech | DIY-CNC Router Table Machines | 4 | 11-28-2004 06:26 PM |
| X-Y (Sliding) Table Recommendation | edge | General Metal Working Machines | 9 | 08-13-2003 11:20 AM |
