Old 10-29-2007, 08:52 AM
jafgreen is on a distinguished road
Milling 440c Stainless Steel
Having issues machining 440c Stainless Steel heat treated to 55Rc to the core. My problem is milling the bosses flat. I need to hold them flat with in .0015" from one side of the boss to the other side.
Looking for help
Attached pictures is the part in question along with my work holding method.
ID:	45999   Click image for larger version
ID:	46000   Click image for larger version
Old 10-30-2007, 08:16 PM
kwhizz is on a distinguished road
Are you Machining one side then flipping the part to do the second side??If so you are leaving yourself open to error as is seems you are clamping on a forged surface .......Machining, then reclamping......distortion from Clamping and Machining Pressure (on initial clamping....is there a adjustable clamp support behind the area being Machined to keep the Cutters from killing themselves from vibration).......Also any error in the forging will show as the part is flipped.........Or are you doing both sides in one clamping with a rotating fixture.....(Better chance of Success)........
Ken
Old 10-30-2007, 09:12 PM
cdlenterprises is on a distinguished road
What are the issues? Tool life? Holding tolerance? Processing? Give us something to go on if you can....
I don't know much about anything but I know a little about everything....
Stainless steel larry53 General Metalwork Discussion 4 04-23-2007 12:32 AM
Steel or Stainless tool_man Casting Metals 2 10-29-2006 06:46 AM
Stainless Or Steel 69owb Mechanical Calculations/Engineering Design 5 10-03-2006 02:43 PM
Stainless Steel ? Depoman General Metalwork Discussion 2 01-12-2005 06:40 AM
Is stainless steel CNCadmin Hard and High Speed Machining 12 10-17-2003 09:19 AM
