Old 10-29-2007, 07:38 AM
kwhizz is on a distinguished road
Tapered Seat Finish
We are turning some parts that have a 60 Degree Internal seat in them....It starts at about 7/16 and tapers down to about 3/32 where it meets the center thru hole.....we are putting the taper in with a small Boring Bar because of the small thru hole........we are having trouble with consistancy of the surface finish.....material is 4340 ....28-32 rc......Is there any tricks or special Tooling for getting rid of the circular boring finish grooves.......need to be a 1Rms or better on Profilimeter readings.....
Ken
Old 10-29-2007, 09:34 PM
307startup is on a distinguished road
It sounds like a combination of a VERY small radius insert & much smaller feed rate is going to be necessary to accomplish that finish...
Old 10-29-2007, 10:10 PM
ctate2000 is on a distinguished road
Use a center lap to finish the operation. Buy it from MSC. Put the lap in drill press and turn slow if you can't see the flutes as the tool turns you are going to fast. Hold part against tool with hand pressure and lap to achieve finish. You may want to leave a thou or three for finish as the lap will cut slightly. The lap is not usually agressive enough to move the hole but I would verifly the dimensional correctness on the first few parts. Try to get the best finish possible from the machine tool before lapping. Oil the lap good each time and blow the flutes clean before each part. You can use the machine tool to do this if you are trying avoid hand work I would feed to depth and dwell for 1 sec or so with lots of coolant.
Old 10-30-2007, 09:45 PM
cdlenterprises is on a distinguished road
Your not going to hold a 1 RMS finish using any conventional machining method that I know of. Lapping as mentioned before is probably your best bet. This is a huge shot in the dark but you may be able to burnish it some how, but the small size may be a problem. I would give the guys at Cogsdill a call and see if they can help....
I don't know much about anything but I know a little about everything....
I'm looking to buy a used seat of Gibbscam zak GibbsCAM 4 07-03-2011 11:38 AM
Anyone interested in a used seat of OneCNC Lathe? Edster OneCNC 3 03-07-2007 11:19 AM
I might buy a seat if.... bpmufx MadCAM 11 12-07-2006 09:58 AM
About to become the youngest seat holder in OneCNC Cold Fusion OneCNC 13 06-28-2004 03:23 PM
onecnc in the driving seat peter OneCNC 22 12-09-2003 03:52 AM
