| Hi I'm building my first CNC using 1" lead screws & need nuts to suit (4) 4 would be good these are 4 threads per inch, new price is prohibitive as this is supposed to be experimental, the screws arew an old 4 poster car hoist worn but still serviceable for my job as loading is minimal. |
| You could cast your nuts from Moglice, or your own epoxy-graphite/teflon powwder mix.
| If you have a piece of the lead screw left over you can use it to make a tap that will cut throught delrin. You will have to tapper the end and add some deep grooves down the sides. When you make the grooves try to keep a clean 90 degree edge on the leading side. Dan |
If you have a lathe, you could make your own acme nuts that would fit better and last longer than purchase items. Chances are, your lead screws are worn, and new nuts are likely to be loose. Of course the ideal solution would be to have your leadscrews reground and then fit custom nuts to them because if they are worn, they will be more worn in the area where they are most used. rgengstrom |
| Dumpster AB lead nuts | SCHootie | DIY-CNC Router Table Machines | 4 | 02-18-2007 07:39 PM |
| Rotating lead nuts | Tom Brown | DIY-CNC Router Table Machines | 69 | 09-29-2006 10:25 AM |
| Belt vrs. Ball Screw vrs. Lead Screw | stevesplanes | Linear and Rotary Motion | 7 | 01-09-2006 12:23 PM |
| New technology.... old debate.....ball screw vs lead screw | trubleshtr | Linear and Rotary Motion | 1 | 08-15-2005 09:42 PM |
| Ball Screw and Lead Screw | ljoe1969 | DIY-CNC Router Table Machines | 9 | 11-21-2003 09:06 AM |
