Hi, I will be using a solid carbide drill for the first time, just want to get some input on feed and speed for it. I will be drilling a .422 dia hole for a 1/2-13 tap, in round bar. Round bar is .875 dia, and is 4140 HRA. I am using a cobalt twist drill now - we centerdrill, drill, c-sink and tap. But with the solid carbide drill, should i use a center drill? I can sacrifice a lower feed n speed if it will increase tool life, I'm not in that big of a hurry! |
| Carbide likes running at higher feeds and speeds - babying it might increase the life but I doubt it will have a substantial impact. Center drill? I suggest it as a general rule. Solid carbide drills have a thicker web than a typical drill - depends on the manufacturer. They are stiffer though and are less likely to walk but on round stock they still can. I would center drill - it's just a good habit in my opinion. Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
| Is this on a CNC lathe? Are you using soluble oil with chlorine? 3 or 5 diameters deep? With a short 3 diameter deep drill, you can usually skip the center drill. Is the drill coated with TiALN or TiCN or TiN? Split point? Best case: 3x diameter, soluble oil with chlorine, TiALN coated with high performance split point. For those conditions, you could run 400 sfm (3000 rpm) and .012"-.014" feed per turn (36-42 inches per minute) with good tool life. Even backed off to 300 sfm, it's still a fast hole. If I were tapping 1/2"-13 blind in 4140, I would drill a 7/16 hole. The stress on the tap and likelihood of breakage is a lot lower. Dave |
| Reshrpening Solid Carbide Tools | brainlessme | Toolgrinding & Toolgrinding Machines | 0 | 04-29-2007 03:23 AM |
| clamping of solid carbide drills | dhiruj | Metal Working Tooling | 11 | 03-27-2007 02:02 PM |
| Carbide drill VS indexable drill | kalmah | General Metalwork Discussion | 8 | 11-08-2006 07:48 AM |
| Guhring Solid Carbide Drills | bma137 | General Metalwork Discussion | 14 | 08-16-2006 08:13 PM |
| Drilling INTO carbide | runnoahrun | Hard and High Speed Machining | 11 | 02-09-2005 03:33 PM |
