Old 10-24-2007, 11:06 AM
CNC_BOB is on a distinguished road
316 L Stainless
if anyone has a suggestion for machining a cavity in 316L stainless I would appreciate it. I used a 5/8 Sandvik bullnose to get as deep as I can but the walls taper down and I have to get the rest of the material out with a 1/2 in. ballnose endmill. I have tried HItachi, Diejet and Dapra and all of them with poor results. I am beginning to wonder if a solid carbide ball would do any good.
Old 10-25-2007, 08:21 PM
cdlenterprises is on a distinguished road
For solid carbide I'd go with TiAlN or TiCN coating. The -SS series from Dataflute or the SGS ZEE CARB have always worked well for me. I would drill out as much as I could, but I assume that you will have already thought of that. 316 is reasonably tough so good luck.
I don't know much about anything but I know a little about everything....
Old 10-26-2007, 01:48 AM
JonS is on a distinguished road
I have found 316 a nightmare, it seems fine then you get it a touch hot and it work hardens and it will blunt any HSS coated or not in a moment.
I would go with the coated carbide suggested by cdlenterprises and keep it really cool - the 316 and the beer
Sliding down the razor blade of life.
TM-1 and milling stainless CJH Haas Mills 13 07-29-2007 09:43 AM
304 stainless on vf-2 jprobst Haas Mills 6 06-12-2007 08:28 PM
casting stainless tanz Casting Metals 1 06-05-2007 12:28 AM
Stainless 304 pauls General Metalwork Discussion 11 06-04-2005 04:50 AM
Is stainless steel CNCadmin Hard and High Speed Machining 12 10-17-2003 09:19 AM
