Old 10-23-2007, 07:43 PM
Maia is on a distinguished road
Making V-blocks
In school I opened my big mouth and now I have to make a set of V-blocks for everyone in the class as my final project. I am making them out of 6061t aluminum that will be hardened when finished. The milling should be pretty easy by using a sine bar and leaving .005 on all surfaces for grinding. My question is how do i grind the V slots?
Old 10-25-2007, 12:36 AM
SIG SIG is offline
SIG is on a distinguished road
Wink
I would finish mill them. Only if I were making steel V blocks would I heat treat and grind.
Grinding: Put the parts on a magnetic sine plate or dress 45s on your wheel with a sine dresser.
Good luck with your project and remember The wise old owl.
Making you own DYI rail for linear blocks java77man Linear and Rotary Motion 7 06-25-2007 11:00 PM
RFQ for maple blocks CNCadmin Employment Opportunity 8 04-10-2007 03:41 PM
Blocks for Leadscrews Mcgyver Mechanical Calculations/Engineering Design 9 10-12-2005 12:04 AM
iko blocks seem too stiff. bgolash DIY-CNC Router Table Machines 4 03-14-2005 02:50 PM
Making your own pillow blocks and Rail mounts? Zephrant DIY-CNC Router Table Machines 20 05-19-2003 07:34 PM
