Old 10-22-2007, 08:46 PM
nightshift is on a distinguished road
warpage machining 6061
I had a problem milling a 6"x24x 1/2" plate. nc prog mills .05 off top and periphery, drill and taps a dozen different holes.There are a bunch of M0's to relieve part in vise jaws (3vises). plate starts out at 3/4" thickness and is dusted on both sides initially. After milling ,drill and tap (6-32,8-32,10-32),the part is flipped over and rough milled to thickness leaving .02 for 2nd flip and final thickness.Im using a 3" 4 tooth mill {shear hog ,polished inserts, flood coolant). plate bows about .01 after roughing.I've run these many times in the past without too much trouble.
The stock I got last week warped big time (.03) . The more I mill these things
the worse they get. Would this stock have the wrong temper or be the wrong grade of aluminum ,look the same.
Old 10-22-2007, 08:57 PM
PBMW is on a distinguished road
You're putting stress into the part as you machine it most likely. 6061 is pretty stable. I just did a job that was 22 x 10 x 2.5. Cut lots of pockets and never moved. Pockets both sides. Floors finished at .093. Walls were pretty thin as well. about 80% of the material went in the chip bin. You can control the stress to an extent with speeds and feeds. Use radiused cutters too...
Old 10-22-2007, 09:02 PM
This part is generally not a problem.raw stock is suspect though
Where to get 6061 hex in metric? grinderdust General Metalwork Discussion 4 10-07-2007 10:22 AM
machining 6061 aluminum conlimon Benchtop Machines 16 09-19-2007 08:20 PM
Plasma Warpage Problem FCDL36X7S3 CNC Plasma and Waterjet Machines 3 07-26-2007 04:47 AM
Worried about plate warpage willrogers CNC Plasma and Waterjet Machines 4 10-05-2006 10:33 AM
Parts RFQ Machining 6061 hoju1301 Employment Opportunity 6 07-11-2006 07:07 PM
