Old 10-17-2007, 04:06 AM
Lance Reid is on a distinguished road
Aluminium type
Yello, I have a piece of Aluminium plate without any markings on, is there any way to get a rough idea of what grade it might be?
Cheers, Lance
Old 10-18-2007, 09:57 PM
dpuch is on a distinguished road
Grade... probably not.
I would suggest checking hardness, also cut a slice and check how it bends. possible how easily it corrodes. But turning that into a material series... I think not.
Dale
Old 10-19-2007, 10:00 PM
bookwurm99 is on a distinguished road
take the metal to a scrap recycling yard and have them hit it with their alloy analysis gun.
bookwurm99
Old 10-22-2007, 03:33 AM
Thanks for the replies, I didn't know about the alloy testing gun, I know someone in a scrapyard and will see if they have one, cheers
Old 10-23-2007, 06:50 PM
i didnt either until i was selling some old copper from transformers and from a generator armature (sp?). this was back in jan or feb. then i saw a guy at work checking the alloy of some threaded studs that were made overseas some where. he had one made by Niton. i want to know the price of one because i might get one eventually. that purchase is probably at least 10 years away.
Old 10-25-2007, 08:27 PM
cdlenterprises is on a distinguished road
There is a chemical test that can be done that will tell you the alloy by the color that it changes. It's been a long time since I've seen it done but I know it exists. You might try to google "aluminum chemical test" or something and see what comes up. As far as I can remember it is a non-destructive test, similar to a Rockwell hardness test or a spark test.
I don't know much about anything but I know a little about everything....
Old 10-26-2007, 01:55 AM
JonS is on a distinguished road
if you were to try anodizing it then the impurities would result in colour which would give you some major hints as to what type of Alu it is... I guess this is similar to the chemical test.
quote from google - "Niton's handheld alloy analysers use x-ray fluorescence technology to allow inspectors to confirm the alloy composition of a wide range of metals, simply by pointing the detector gun at the metallic surface.
Within seconds the gun displays a detailed readout of the composition of the alloy. Excellent for analysis of metal alloys for PMI, scrap metal recycling and QA/QC, as well as analysis of soils and sediments, environmental monitoring, lead in paint assessment, geochemical mapping, and more. "
Sliding down the razor blade of life.
Coolant for Aluminium Nigel_B Australia, New Zealand Club house 13 03-03-2007 05:25 PM
RFQ: Aluminium Bushings levelzero Employment Opportunity 3 03-01-2007 02:04 PM
DIY Aluminium milling anyone? Oldmanandhistoy DIY-CNC Router Table Machines 9 10-21-2006 10:56 AM
'What type of aluminium to buy to cnc rout out? Apples General Metalwork Discussion 3 09-27-2006 05:20 PM
Cutting Aluminium ninewgt General Metal Working Machines 3 07-29-2003 01:31 PM
