I need to mill out a pocket that is 1-1/2" deep in 6061 aluminum. The pocket is approx. 5.25" long and 2.5" wide with large radiused corners (see attachment). I am concerned about the finish of the pocket, how would you recommend machining this? Machine is a Haas VF0E. Here was my taughts: Held in a Kurt Vise rough out the center pocket leaving 0.015" all the way around and using the same tool make a finish pass to clean it up. Tool would be 2 flute Carbide with a 1-3/4" flute length. My concern is chatter with the long e.m. and also the corners when changing from climb to conventional milling. Any suggestions would be appreciated. |
I think 0.015 is way too much for finish cut. Using 4 flutes on the finish cutter, and running cutter slow enough that it doesn't resonate. Try to to keep the feed rate up on the finish pass. 4 flutes should give nice overlap. Going all the way anti-clockwise around will be climb milling. How can it not be? Main problem is selecting approach/depart point. Make sure you change the feed rate going around the ends, so that the cutting edge sees the same advance size per flute. Reduce by ratio of radii I think it is.
__________________ Super X3. 3600rpm. Two possible way to fix things: The right way or the other way. |
| I'd use this gorilla mill 1/2 1-1/2 4.0 GMA12FL3 http://www.gorillamill.net/nonferrous.html I use em, and love em!!! You can use the same tool to rough and finish. Use a spiral out type tool path, and you will be fine.
__________________ "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet |
| Thanks for the info. big_mak I will check into the gorillamill endmills, I am a big fan of the Niagra stuff but always looking for cheaper/better end mills. We have some new Niagra HSS TiCN 3 flute endmills here that are 0.75" diameter 1.75" flute lenght. According to Niagra they recommend 3210RPM and 72IPM when running at there recommended 630SFPM and 0.0075" FPT. The axial depth would be 0.375 Do the feed and speeds look right for HSS? The RPM seems too low Also the cam software is not compensating for the radius in the pocket, is that critical? |
3200 is flyin for HSS and .0075 is an aggresive feedrate. You may want to keep your hand on your overides and start in easy with those settings.
| What to do about mill table that has been milled into? | cut more | General Metal Working Machines | 5 | 07-13-2007 07:32 PM |
| Looking for Milled Compressor Wheels | AMCTony | Jet Engines and Ram Jets | 1 | 05-16-2007 08:17 AM |
| RFQ for 120QTY 5/8" Round Stock Standoffs 6061 Aluminum | mpstech | Employment Opportunity | 6 | 09-20-2006 04:02 PM |
| RFQ Al plate/milled | roninB4 | Employment Opportunity | 8 | 09-07-2006 02:23 PM |
| Never milled but have a project | mikesativa | General Metalwork Discussion | 9 | 03-22-2006 02:24 PM |
