Old 10-05-2007, 08:30 PM
abdmalki is on a distinguished road
Corian Material
Folks,
One of my Friend working in a plant produce a corian coutertop plate asked me what is the best production method to make a decorating shape (cutoff)
on a 600x600x7mm corian piece (20,000+ pcs) .
One of the consider method is using a CNC router but due to a limited time
and a low production cost they want, this method is not suitable. Also they tried a casting method but they did not succeed.
Have any of you had any experience with materials like this , any
suggestions?
Thanks,
Abdu
Old 10-05-2007, 11:34 PM
One of Many is on a distinguished road
Water jet would be your only other option if you expect special profiles with odd angles. The hourly cost for one of these is quite a bit more than a router though.
The material is very abrasive, but cuts decent with carbide. Cutter life will be your biggest issue, beside some sort of vacuum to pull the dust clear from the cutting area.
If there was a chance that the material could be cut partially through with the properly selected cutter and snapped\fractured apart with decent results, there could be some savings in cutting through. This may include some slight belt sanding work to clean up the edges.
Wear a face mask!
I was very surprised to see this material being cut with lasers. That can't smell very good!
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Corian for a table? js11110 DIY-CNC Router Table Machines 14 12-21-2009 12:51 AM
Corian Laser Cutting abdmalki Laser Engraving & Cutting Machines 6 05-06-2008 07:30 AM
Vac forming Corian? fer_mayrl Vacuum forming, Thermoforming Etc 6 08-21-2007 07:15 PM
Aussie source of Corian wjfiles Australia, New Zealand Club house 3 08-02-2007 02:19 AM
Corian as a slide? chuckknigh DIY-CNC Router Table Machines 13 04-27-2004 08:44 AM
