Old 10-04-2007, 02:09 PM
Rich05 is on a distinguished road
Depth Cut Verses Feed Rate? 6 hr operation..
A bit confused here.
MC program has the half inch 2 flute endmill speed rate suggested at 12 ipm, but this does not take into account the depth cut I have set at .125..
I am running 2hp Industrial Hobbies mill around 3,200 RPM. What depth cut should a 7/16 or 1/2 two flute endmill Tin Coated and HSS be doing? If the depth cut is .125 what feed rate should I be running at? Or is .125 too conservative for 6061 aluminum.
The part I am cutting is 25" long about .75 deep with pockets and so forth. Right now with 12ipm feed rate at .125 it is taking about 6 hours. Looking to reduce this time without wearing out stuff
Mill 3200 rpm 2hp Industrial hobbies, with Mist (NO FLOOD).
6061 Aluminum x=30" y=6" z=.75" stock
R.
Old 10-06-2007, 06:01 PM
DSL PWR is on a distinguished road
It is hard to suggest feeds for a mill that I'm not running. Just run the spindle as fast as the tool can take, and in aluminum bump up the feed rate until:
a: you run out of power
b: you can't clear the chips out,
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 10-06-2007, 06:39 PM
rgr
discovering optimum speed is quite an art.
Thanks much
Old 10-09-2007, 10:09 AM
JDenyer232 is on a distinguished road
At 12 ipm you are feeding to conservativly. Your chip load is only .002, with a 1/2" mill I would run with a chip load of .003-.004 which would put your feed rate at 20-25 ipm. I would reduce the depth of cut to .100 and try it at 20 ipm for a start. According to my software you would be using a little over 1/2 a horsepower to achieve this. Of course I would also use a 3 flute mill in order to run at an even higher feedrate. Hope this is of some help.
Old 10-09-2007, 10:25 AM
roger that I bumped it up to about 20imp now with no problems really. have gotten a couple chipped endmils no idea how that is happening the part is well ancored maybe larger chunks becoming lose during contouring operation.
R
Old 10-09-2007, 11:23 AM
R
Are you cutting dry? You really will need coolant to achieve max feed rates and not chip the endmill or gouge the aluminum.
Old 10-09-2007, 11:35 AM
using mist coolant only..
Old 10-09-2007, 12:58 PM
Mist is ok if that's all you got, flood is better as it gets the chips out of the way. A strong stream of air works well for chip removal as well, the idea is to not be recutting the chips. Try a 3 flute end mill, I think you will be impressed.
Old 10-09-2007, 01:11 PM
Oldmanandhistoy is on a distinguished road
Do you mind me asking what software you are using?
John
Old 10-09-2007, 02:15 PM
Originally Posted by Oldmanandhistoy View Post
John
Millworks, it's a free speed and feed utility that calculates feed, speed, horsepower, amount of material removed per minute, etc. Here's the link
http://lovejoytool.com/free.htm
I use this all the time when I program our VMC, works like a charm for getting you pretty close to where you need to be as far as feed and speed goes.
  #11   Ban this user!
Old 10-09-2007, 02:26 PM
just wanted to say thanks for the advise on this thread. I know the question was quite open ended, which is never a good thing, which takes some patience to answer. Cheers.
R
  #12   Ban this user!
Old 10-09-2007, 02:30 PM
Thanks for that; I have an old copy of ME Consultant 2.0 which gives the same numbers as you did other than the power requirements which is 0.284 HP for a full width cut.
Looking back at the first post in this thread I noticed a Tin coated HSS EM was being used. From what I have read on the zone Tin is a bad choice for use with aluminium as the chips stick to it. Ticn coating is better but more difficult to find on HSS.
John
Feed Rate? bearwen GRZ Software- MeshCAM 3 04-26-2006 05:52 PM
Where's the Lathe Speed, Feed, and Depth Data?? Otokoyama General Metal Working Machines 4 02-06-2006 02:14 PM
C & Z Feed rate rfstar G-Code Programing 7 06-22-2005 01:38 AM
How can I up my feed rate ? ynneb DIY-CNC Router Table Machines 7 07-12-2004 10:40 PM
Another feed rate, cut depth question nervis1 General Metal Working Machines 8 02-10-2004 12:56 AM
