I just got a new job in requiring 12mm (.472") square bar 303SS. I found 12mm square stock but its about $1200.00 more that just 1/2" square. So I thought next to just buy 1/2" square and double disk grind it to 12mm and save some money. But they want $6.00 per part x the 200 parts that equals $1200.00 that's same as just buying metric material. So my question is do you think I can skim cut off 0.028 off two side in my mill and make 12mm square material or is the material going to bow or tweak out because it cold drawn SS. Any help would be nice. Thanks, Neil |
| How long is your piece? Depending on the length of your piece you might see some warpage. What other operations do you have to do to these pieces? The more you have to handle your parts the more expensive they will be to make. |
| The parts are 6" long. The first op is to do some mill work so that was why I was thinking this time to also machine them to the correct thickness and same some money. I made two last time with 12mm stock and now they re-ordered 200 and it's a on going part. I guess I will find out Monday when I get the material and give it a try. If not there going to double disk. Thanks, Neil |
If you take a cut only off two sides they will distort by many thou is my expectation. You might find taking off a cut like this results in a 1/64" to 1/32" bow; I may be too pessimistic but you will soon show if I am.
| I did say I may be too pessimistic .If the 600 was a guaranteed number I would be tempted to talk to the supplier of the 12mm square stock and give them a song and dance to get a better price if I buy a larger quantity.
| It might be worthwhile speaking to the customer and see if 1/2" stock would be ok instead of 12mm... I've done this many times and you'll be surprised at how many designers/ customers say "yeah, sure- that was just nominal dimension anyway".
__________________ I love deadlines- I like the whooshing sound they make as they fly by. |
#10
Just as a FYI I finished all of the 200 parts on Tuesday. I had to machine all four sides and take 0.014" off of them. If I only machined two sides the material would bow about 0.020". But by taking 0.014" off of all four it stayed within 0.005" of flat. Good enough for a 7" long part. I wish I could use 1/2" material but this bar has to go between two other parts that have 12mm grooves machined in them. Thanks again, Neil |
#11
| What speeds and feed are needed to weld a SML drill into 303SS? | cacrawfo | CNC Tooling | 7 | 05-14-2007 01:31 PM |
| X3 base size or minium bench size | kenrc | Benchtop Machines | 2 | 02-04-2007 07:50 AM |
| 303SS loads/feeds/etc - tiny cutters | zcases | General Metalwork Discussion | 5 | 01-16-2007 09:07 AM |
| Machining the ends of ballscrews & ball screw size | Zumba | Linear and Rotary Motion | 4 | 02-15-2006 11:47 AM |
| Problem machining accurate size part on my Bridgeport CNC conversion | fastturbovet | General Metal Working Machines | 5 | 05-24-2005 01:01 AM |
