  #13   Ban this user!
Old 10-09-2007, 07:01 AM
dkowalcz's Avatar
dkowalcz is on a distinguished road
I do a fair bit of delrin production work - just program your CNC to "peck turn" and you're done.
It also works to take a few radial plunges every 1/2" or so down the length first and then do a regular roughing pass across them, but it's slower than the pecking method. If you're on a manual lathe though, that's the way to go.
  #14   Ban this user!
Old 10-09-2007, 08:48 PM
307startup is on a distinguished road
DKOWALCZ what in the heck is peck-turn on a CNC lathe? I've never even heard of a term like that before... I like the idea, but unless there is a relevant modal G code for that, I don't even want to try manually inputting that code in my machine, good lord that'd add XXX amount of lines to every program I've ever written.
I'll admit having been a manual machinist as well as a CNC machinist for only 3 years, that's not a lot of code compared to some people, but more than most people with my time in the field. And I do mean CNC machinist, not operator, as I can diagnose & field repair machines, program, edit, set-up and tool-up machines. At least all the ones I have seat time on.
I used to turn HDPE for a company that makes plastic fusable fittings for water/gas lines (the big ones) on a manual lathe, and I just used a boxcutter to score the profile before I made a pass. It really helped keep the mess manageable, as having 20-30 feet of ribbon wrap around the spinning chuck and whipping the hell out of you before you can stop the spindle is a real experience...like when the 18" diameter (45 lbs.) part you are working on comes unchucked and bounces into your face because the flapping ribbon grabbed the toolpost and forced the tool deep into the part. You will never forget an experience like that. Makes taking the time to stop the spindle and score the workpiece every pass a necessity...unless you don't mind having a broken nose and a few missing teeth because of an occupational hazard that you could prevent.
  #15   Ban this user!
Old 10-09-2007, 09:10 PM
I did notice, at least with HDPE, that when we brought stock in from the yard during the colder months, that it cut much "nicer"...the liquid nitrogen trick would definitely work, but man, what a PITA.
Personally, I have always thought that there should be an insert made specifically for plastic that has the cutting edge and then an edge that just makes contact with the part when the cutting edge is at depth, sort of a lobster claw arrangement with the longer edge above center line, that has a serrated element to it, or is heated, similar to a wire foam-cutter, just to help break the chip. If the plastic part was a big-ticket item, or constant production, it would really help and also justify such a specialty tool.
Or, on a CNC machine or manual lathe, just cut an appropriate left-hand thread to depth the length and profile of your piece, so when you take a normal cut, there are automatic chip breaks.
I know, not much help...but maybe it'll jog the brain of some tooling engineer to take up this issue. Especially since there are a lot of specialty plastic parts that don't justify molding or require the safety factor of machining from stock, ie. no voids in the material or excessively thin areas due to cooling shuts...
  #16   Ban this user!
Old 10-10-2007, 12:42 AM
Originally Posted by WYLD View Post
DKOWALCZ what in the heck is peck-turn on a CNC lathe? I've never even heard of a term like that before... I like the idea, but unless there is a relevant modal G code for that,......
Going from memory here.....peck turn is G74 Peck Face Grooving Cycle; peck face is G75 Peck Grooving Cycle. I use them I am just not sure if I have the correct G number. You set how far the tool advances per peck and at least on my machines (Haas) you define how far it retracts in a Setting.
Really useful canned cycles, I use them a lot for roughing large amounts off6061 to avoid big chip tangles.
  #17   Ban this user!
Old 10-10-2007, 08:46 AM
dkowalcz's Avatar
G78 for peck arbitrary axis on TurboCNC - but it's more powerful to write a loop macro to do it as the g-code does a full retract which isn't necessary.
Most CNC's will take loop input of the form ... Ln where L is "repeat this line n times" so:
G91
G01 Z-0.100 F10.0 G04 P0.25 L9
gives you an inch of peck with dwell rather than retract, which should be good enough most of the time. If not, there's always "copy/paste programming".
Looking for a used Roland 650 or similar benchtop CNC? KMetcalf DIY-CNC Router Table Machines 2 12-26-2006 02:06 PM
X2 or similar in Canada? Jester966 Benchtop Machines 6 10-17-2006 06:31 AM
Delrin, HDPE or similar in Aus? Agro Australia, New Zealand Club house 17 06-09-2006 05:47 PM
Similar Threads listed CNCadmin CNCzone Site News and Contests 0 01-10-2005 10:25 AM
