Old 09-26-2007, 03:19 PM
jackson's Avatar
jackson is on a distinguished road
Banjo Fitting
I need a little help OK i need alot of help but thats another subject i need to machine a banjo fitting and i cant figure out how to calculate the distance from the face of the part to 1" diameter i have attached a print
Thank you,
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Old 09-26-2007, 04:33 PM
turmite is on a distinguished road
Hey Jackson,
Do you want the distance from the bottom of the threads to the start of the small radius that you blanked out, or to the edge of the 1" diam of the body of the banjo?
The distance from the threads to the diam of the banjo is .699" and that is using the diam of the threaded shank of .540" like on the print. The distance to the small .130" radius blend between the shank and the diam of the body is .633".
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 09-26-2007, 04:36 PM
jackson's Avatar
ok how do calculat that
Old 09-26-2007, 07:22 PM
Jackson I did it with cad. I am terrible at math. Do you have cad?
Mike
Old 09-27-2007, 07:29 AM
Andre' B is on a distinguished road
This should get you started.
Edit: trying for a better pic.
Old 09-27-2007, 07:30 AM
jackson's Avatar
No but i can use your numbers to figure it out "maybe" LOL
Old 09-27-2007, 08:41 AM
jackson's Avatar
Thank you that works great i guess i need a cam system but even if i had one i would want to know how to hand figure it
and again thanks
Old 09-27-2007, 09:54 AM
Hey Andre'B thanks for helping.
Jackson this is what makes this site so great.
As I told you, I am, no good at math, and I'm so glad I have cam and don't have to figure it by hand otherwise I would sure enough never get anything done!
Mike
Old 09-27-2007, 10:16 AM
jackson's Avatar
Mike
Yeah i probably need to break down and get a system im just putting it off. but im one of these people that i have to know how its done. but for the recored in not that good a math i can do just enough to get by LOL!!!!!!!!!!
Re-fitting a mill gunner312 Benchtop Machines 1 07-11-2007 09:31 AM
M6 x 1.0mm grease fitting N4NV Mechanical Calculations/Engineering Design 5 03-31-2006 04:03 PM
Retro fitting new2this Industrial Hobbies (Support forum) 1 01-21-2006 06:21 PM
Hose-fitting supplier - please help DrStein99 Mechanical Calculations/Engineering Design 23 11-28-2005 11:20 AM
cnc fitting a bridgeport MBG Bridgeport and Hardinge Mills 5 09-26-2005 04:25 PM
