Old 09-26-2007, 04:28 AM
fizzman is on a distinguished road
Out of center axle turning?
Hi.
In Fanuc, what is a good function to turn an out of center axle. I know it can be done, I just don't know any good functions to do this.
I attached a picture of it. Very nice picture too, 30 sec in Paint.
I would be very grateful if someone has a tip for this. Is it a polygonial turning? e.g G50.2?
Thanks in advance!
Name:	out of center turning.GIF‎
Old 09-26-2007, 06:39 AM
Karl_T's Avatar
Karl_T is on a distinguished road
This why four jaw chucks are made. Mount off center by amount you need.
Karl
Old 09-26-2007, 07:13 AM
jrrdw's Avatar
jrrdw is on a distinguished road
Karl
As long as it's not a self centering chuck, correct???
Make sure you clean my wrench before you put it back into my toolbox.
Old 09-26-2007, 09:13 AM
Ok, a four chuck solution is ok for the out of center axle itself, but how about the axle in center? By using a non centering chuck I can't turn the big diameter axle...
Thanks for the tip, but I'm looking for a way to do this by help of programming.
Old 09-26-2007, 09:19 AM
Andre' B is on a distinguished road
Unless your lathe has a C and Y axis and live tooling I think you will have to do it in to operations.
If the lengths shown in the drawing are relative you could do it in a mill. And if you do not like the milled finish set up two boring heads for finish turning the two diameters.
Old 09-26-2007, 09:27 AM
I have both C-and Y-axis and live tooling, but I dont want to mill it, I want to turn it.
But I think it should be no problem without Y-axis as long as the C- and X-axis are synched, right?
Old 09-26-2007, 10:01 AM
The problem with just syncing X and C is unless the eccentricity is small relative to the diameter being turned the rake and clearance angles on the cutting tool change a lot when going thru a revolution of the part.
Name:	Eccentric Turning.jpg‎
Old 09-26-2007, 10:26 AM
Yes, I recognize that this could be a problem. But is there a way?
Thanks for all the input.
Old 09-26-2007, 11:02 AM
If you are asking if there is a G code that will do it on any lathe with a C axis then no.
If your lathe can do it the info would be in the programming manual.
Here is a specal chuck that can be used for eccentric turning on any lathe with a C axis.
http://www.workholding.com/product2_2_1_1_4.html
Old 09-26-2007, 11:12 AM
Thank you Andre.
It was a pity that I couldn't do it without an adjustable chuck, but now I know. Thanks!
  #11   Ban this user!
Old 09-26-2007, 02:03 PM
M-man is on a distinguished road
If you first machine one of the diameters and then use your c-axis to cut the soft jaws to get the "out of center" position for work piece.. You might get a balance problem, but just limit the spindle speed or use counter weights...
Spectralight turning center roni21702 General CNC (Mill and Lathe) Control Software (NC) 4 04-04-2010 10:21 AM
Turning Center G40 G41 and G42 jorgehrr G-Code Programing 16 04-13-2007 10:48 PM
Looking for help with Okuma turning center. shawn45223 General CNC (Mill and Lathe) Control Software (NC) 3 02-07-2007 05:06 PM
Turning center sale bdrmachine General Metal Working Machines 0 01-09-2007 07:23 PM
Threading on turning center dholt General Metal Working Machines 11 10-20-2006 02:05 PM
