Old 09-21-2007, 05:51 PM
carguy327 is on a distinguished road
Exclamation Aluminum not behaving
Hello Everyone,
I usually mill out shapes in aluminum with a ¼" bit , an onsrud o flute: works great. Even when cutting dry.
Now I have to cut using an 1/8 inch and I'm going thru bit like crazy.
I'm feeding at 20ipm and around 12000rpm, 0.02 passes over .080 5052. dry..I think everything is getting too hot.
Any suggestions
Gerald
www.imperium-design.com
Old 09-21-2007, 06:43 PM
cncwhiz is on a distinguished road
Assuming you re using a 2 flute e/m? Your feed rate is way to low for the rpm. If you were to go .005 ipr, you would feed at 120 ipm. You are rubbing the tool to death.
Old 09-21-2007, 08:45 PM
mark c's Avatar
mark c is on a distinguished road
One thing I noticed is you said "dry". You need SOMETHING in the way of coolant/oil. Flood coolant is best, mist would be OK. Even a spray of WD-40 is better than nothing on aluminum. Aluminum is easy to machine, but it likes to gall and stick to the cutter, so anything you can do to lessen this will help.
Either slow the RPM or increase the feed and give some sort of lubrication and cooling to the tool. You'll see a BIG difference
HTH
Insanity "doing the same thing and expecting a different result"
Mark
www.mcoates.com
Aluminum jomarl CNC Plasma and Waterjet Machines 0 09-05-2007 05:03 PM
Help - Motors Not Behaving Firebird0095 General Electronics Discussion 1 11-15-2006 09:01 AM
stepper behaving awkwardly shaiqbashir Stepper Motors and Drives 8 03-27-2006 08:41 PM
Aluminum L pminmo CNCzone Club House 7 11-24-2005 03:01 PM
CNC Aluminum studysession General Metal Working Machines 6 02-12-2005 09:39 AM
