Old 09-18-2007, 01:52 PM
Chris Baird is on a distinguished road
Stainless Steel : Resistant to Tannic Acid
Hi, I need some stainless steel shim stock that is resistant to tannic acid (from wood). I have some stainless shim stock that reacts with the tannins as a blue stain.
Does anyone know of or can point me in the direction of stainless shim stock which wouldn't react with tannic acid?
Old 09-18-2007, 07:19 PM
crazythunder is on a distinguished road
Probably looking for 316L or may have to go with a passivated shim stock that has the pores closed on it. 318 might work but a lot harder to get. I do think any of the 400 series will work, you might could try some 13-8, 17-4, or 15-5 but again they are also going to be hard to get.
Stainless steel larry53 General Metalwork Discussion 4 04-22-2007 11:32 PM
Steel or Stainless tool_man Casting Metals 2 10-29-2006 05:46 AM
Stainless Or Steel 69owb Mechanical Calculations/Engineering Design 5 10-03-2006 01:43 PM
Stainless Steel ? Depoman General Metalwork Discussion 2 01-12-2005 05:40 AM
Is stainless steel CNCadmin Hard and High Speed Machining 12 10-17-2003 08:19 AM
