| These work well for holding carbide on a grinder. 3M double-coated tapes |
| We use carpet tape sometimes here... watch out though, we also use Premiere 600 Synthetic Coolant, and so much as a drop of this stuff anywhere near the tape causes it to release almost instantly. Consequently, we've been known to take a little coolant from the CNC and squirt it on a stubborn sticker to remove it. Works scary good, and kinda makes you more nervous about getting it on your skin, because it SEEMS pretty harmless and non-offensive. All I ever use the tape for is to hold down acrylic sheet now and then, or the odd piece of aluminum for drilling or engraving only. However, back in the day, I used to use it all the time on the CNC router for wood and plastics. Also, the base of the router was foamy PVC Sintra, and almost always either urethane foam or acrylic sheet (and sometimes Rexolite) Your mileage may vary. |
Wow, that is GREAT to know. I stay away from tape because of the difficulty in getting the part released. I've tried other solvents with less than satisfactory results. Where do you buy your coolant? Thanks, Walt |
| I get my coolant from McMaster - It's listed under Machining and Grinding Oil Concentrates as the fully synthetic version. It doesn't really seem much like an oil, but more like some weird concoction of organic amines and other chemicals. It cuts with water at about 15:1 to 30:1, completely prevents rust, and cleans off with water. It's slippery as hell when its wet, but when it's dry, especially on our painted concrete floor, it actually gives you a squeaky, grippy surface with your boots. Weird, but good. We'd have idiots with fractured skulls all over the place otherwise. On Mcmaster page 2094, the part number is 1216K16 for the 5 gallon, and 1216K15 for the 1 gallon. It's pretty non-offensive stuff, doesn't get smelly, and rejects oil, so if you've got a skimmer in your sump, it should go a long way. I use it to cool everything. We machine PVC here from time to time, and I even use it on that crap to keep the temperature, and hence, the poison stench to a minimum. I don't have a skimmers in anything, so what we do is just take coolant for spray bottles out of the CNC, and put in new coolant. That way, we get a constant circulation and nothing sludges up. Andy |
If you are doing a lot of sheet stock parts, You might want to try using a vacuum plate fixture. The fixture can be made from an aluminum block that is larger than the sheet you are cutting. Basicly you machine grooves in the area under the plate you want to cut, with a connection hole to the side of the block into which you will connect a small vacuum pump. Use packing material around the outermost groove to make the seal. This will hold down aluminum sheet strong enough to mill with a 1/2" endmill at 4000 rpm and 60 ipm feedrate. To release the part just turn the vacuum pump off. No sticky crap to wash off. I have run 100's of parts on a Bostomatic 1440 mill with this procedure, with excellent results. |
Hello Bultaco! Do you have any photos of your vac setup that you can post? I've always used double stick on a really clean surface myself, but your setup seems worth a try.....BTW , I have a 143 Bultaco myself.....Tom |
| Double sided tape | Greolt | CNC Tooling | 25 | 09-17-2007 04:11 PM |
| 2d Tabs on contour to hold part in blank | metalworkz | Dolphin CADCAM | 10 | 08-24-2007 01:35 AM |
| mastercam code to punch a tape for machine with tape reader | PETE1968 | Mastercam | 8 | 04-09-2007 12:58 PM |
| Double Sided Tape? Really? | wildcat | General Metalwork Discussion | 4 | 12-03-2006 10:47 AM |
| How to get that darned sticky double sided tape off a milled pcb ? | bobJandal | General Electronics Discussion | 12 | 10-05-2006 07:53 PM |
